Scratch on Cylinder Head Combustion Surface
Hey guys. I scooted a head across my concrete slab and put a little scratch about an inch and a half long on the flat part of the combustion surface. It's not very deep but I can catch it with a finger nail. Will it cause any problems or am I being overly cautious? It isn't where the gasket mates..
I bolted it on thinking it will be fine, but as I seem to do more of as I get older, I'm second guessing myself.
Thanks.
Thanks.
1EFF100- Posts : 265
Re: Scratch on Cylinder Head Combustion Surface
So it's in the flat part of the combustion chamber?
I would think it would be fine, probably lucky that that is where the scratch ended up
norm- Posts : 261
norm wrote:So it's in the flat part of the combustion chamber?
Yes, on the flat part.
Thanks for your input.
Give it a light polish to take off any edges
It's already bolted on the engine. It's small enough I figured it would disappear once carbon buildup occurred.dfree383 wrote:Give it a light polish to take off any edges
However, if there's any question it may pose a problem, I'll remove the head and polish it. At this point it'll only cost a head gasket.
Thanks.
Okay, just pulled both heads back off.
There was another smaller scratch that I didn't catch before where the fire ring mates. I polished them a bit with a scuzz buster wheel but I'm not happy with the outcome. The first one would have been fine but the one on the fire ring--even though it was smaller--I'm not risking reassembling as it is. Gonna take both heads back to the machine shop and have a bit more milled off.
Bruce, if these are the 370 truck heads with the bigger 2.08/1.72 valves installed, then could you please take a picture of them after they come back from the machine shop? Specifically, take a pic of a combustion chamber with a new head gasket overlaid upon the head so that the 360* quench is apparent.
Absolutely, Paul.Paul Kane wrote:Bruce, if these are the 370 truck heads with the bigger 2.08/1.72 valves installed, then could you please take a picture of them after they come back from the machine shop? Specifically, take a pic of a combustion chamber with a new head gasket overlaid upon the head so that the 360* quench is apparent.
Here you go, Paul.
https://brucejessie.smugmug.com/My-First-Gallery/i-SwgfHCR
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» How do I stop the detonation
» Cylinder Head ID Help
» "A" vs "C" cylinder head
» which cylinder head do I have?
