A460 Block zero decked. Pistons out 0.0515
gt350hr
dcon
A460 Block zero decked. Pistons out 0.0515 Empty A460 Block zero decked. Pistons out 0.0515
Post  dcon September 19th 2019, 12:58 pm
Got my engine back from builder/machine shop and took a head off. Looks like the piston is out of the deck 0.0515. Acceptable? Crower 4.3 crank, crower 6.8 rods, TFS A460 heads.
A460 Block zero decked. Pistons out 0.0515 P110
A460 Block zero decked. Pistons out 0.0515 P210
e?
dcon
A460 Block zero decked. Pistons out 0.0515 Empty Re: A460 Block zero decked. Pistons out 0.0515
Post  gt350hr September 19th 2019, 2:36 pm
The head gasket better be .090 thick
gt350hr
A460 Block zero decked. Pistons out 0.0515 Empty It is... but
Post  dcon September 19th 2019, 2:38 pm
Would you guys run this? Doesn't seem like a good program.
dcon
Post  dfree383 September 19th 2019, 2:56 pm
It won’t know the difference as long as you have sufficient piston to head clearance
Post  jpierce55 September 19th 2019, 3:07 pm
I would protest some to the machine shop myself.
I would recommend a 2nd meausurement wiith depth gauge or dial indicator on magnetic base. With the 2nd, use a straight edge for piston stop, zero the indicator once level, and measure the travel to the top.....but thats just me. It would me more accurate than a vernier.
jpierce55
A460 Block zero decked. Pistons out 0.0515 Empty Gaskets
Post  dcon September 19th 2019, 3:26 pm
The gaskets I was told to purchase are Cometic, keep in mind the block is o-ringed. 0.080. SS MLS 5. It does not look like it really seals up.
dcon
Post  Mark O'Neal September 20th 2019, 1:04 am
If you want to run the o-rings, you might want to run copper wire instead of stainless.
Mark O'Neal
Post  gt350hr September 20th 2019, 11:48 am
O rings and MLS gaskets are not a good match.
gt350hr
Post  rmcomprandy September 21st 2019, 11:34 pm
If the piston is out of the hole ... it is not ZERO decked.
"O" ringed blocks are usually meant to use solid soft copper head gaskets of whatever thickness needed.
