bouncing timing mark
while checking timing , timing is bouncing. 6 -10 degree at idle... been through this month ago .. changed timing chain ( engine pro) sent distributor back to msd , put my spare magnetic pickup on set gap to 66k every thing was ok . 6 passes later timing is bouncing again .. checked chain ok air gap ok .. timing light is old sears model.. msd 7al3 box pulled all chips cleaned put back.. i cleaned my grounds .over last winter replaced my battery cable runs. any one have any other ideas..
o henry- Posts : 33
Re: bouncing timing mark
Camshaft gear teeth worn? Get a newr timing light.
BBFTorino- Posts : 999
Some of cheaper timing lights work ok with msd and some don’t. Is the idle rpm hold steady?
stanger68- Posts : 502
yea idle is fine , everything is ok except when checking timing. im borrowing different light today to try
o henry- Posts : 33
» Timing mark question/problem....
» Advance Cam or Not ?
» Timing Pointer for Stock Timing Cover
» engine timing and nitrous timing
» 460 1976 Lincoln Mark iv
