Oil pump won’t prime
rmk57
zbob
Emkin
I put a new Kaase oil pump in and can’t get it to prime. The drill is going counter clockwise. Any ideas or suggestions?
Emkin- Posts : 11
Re: Oil pump won’t prime
Emkin wrote:I put a new Kaase oil pump in and can’t get it to prime. The drill is going counter clockwise. Any ideas or suggestions.?
Put 12 quarts of oil in the engine then after it primes, drain some out.
If it still does not prime ... you have other issues.
Did you use a gasket between the block and oil pump?
And between the pick up tube and the oil pump?
BBFTorino- Posts : 999
in the relatively few engines I primed never used a drill. always just used a speed/crank wrench. the description used a politically incorrect term in it. you can guess the rest.
zbob- Posts : 271
Man, if you have a HV oil pump and primed it that way you'd have arms like Hercules when it finally primed.
rmk57- Posts : 176
If you leave those oil gallery plugs out during a rebuild you will get no oil pressure.
jasonf- BBF CONTRIBUTOR
growing up the old school guys would always take the cover off the pumps and put grease in them saying it need it to prime.
So Ive just always poured some oil in pumps before I install them to get oil inside them. Never had a priming issue doing this.
tbirdmike- Posts : 34
tbirdmike wrote:growing up the old school guys would always take the cover off the pumps and put grease in them saying it need it to prime.
Same here. Except I’ve evolved to using assembly lube the last few I’ve built.
stanger68- Posts : 502
So, either a plug was left out somewhere, or the pump is cavitating, or the pressure relief valve is stuck open, or there is a blockage somewhere.
Are sure you have the right size shaft?
wrong pickup tube
no pickup tube
pickup to far away from (oil) bottom of pan
oil filter
main galley plug left out
valley plug left out
not enough oil in pan
oil pump bad
could be a few diff things
no pickup tube
oil filter
oil pump bad
BOSS 429- Posts : 2372
» Oil pump prime tool
» ANYONE RUNNING THE PROCOMP 35GPH ELECTRIC WATER PUMP--sorry, not proform pump
» Fuel Inj. Pump - Ron's Black Gear Pump - Size "0" - SOLD !!
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
