Rebuild gasket set
Gregaust
JBR-3
Rebuild gasket set
Last edited by JBR-3 on October 17th 2020, 3:35 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Re: Rebuild gasket set
I agree on the Printoseal , not a fan at all.
But the felpro blue type small port intakes work nice or I use the Victor Reinz gaskets
Gregaust- Posts : 626
I CAN NOT BE THE ONLY ONE who knows how to install the 1231 intake gaskets, ALL the std layout port heads get thses gaskets, NEVER A FAIL,EVER. This is a great gasket.
On the dyno we have used the SAME gasket over 4 or 5 times changing intakes .
BOSS 429- Posts : 2372
BOSS 429 wrote:I CAN NOT BE THE ONLY ONE who knows how to install the 1231 intake gaskets, ALL the std layout port heads get thses gaskets, NEVER A FAIL,EVER. This is a great gasket.
At least 10 or more times, I have had those gaskets separate right at the print-o-seal line; probably being caused by over-torquing. Sometimes they sucked air or oil and other times not. Once they leave you ... you have no control how tight people make their intake bolts. They seal very well until they don't.
That is part of the reason that Fel-Pro added a steel lamination and added an "S" to the Cobra-Jet part number.
Don't try to make a claim there have been no problems by anybody else out in the field from whatever cause.
If you like them, then use them ... that is totally your prerogative.
Other people, as well, are entitled to voice past issues; self caused, or not.
Simply call Ford Performance Parts and ask them about the failures throughout the years on crate engines where they have had calls about separated intake gasket issues after a few years. AGAIN, they have little control over how tight people make their intake bolts.
So, in essence ... you are one of the only people who know how to install them to have no issues; keep doing whatever you're doing.
Don't try to make a claim there have been no problems by anybody else out in the field from whatever cause. < never said there was no prob, I HAVE SAID NONE OF MY GUYS HAVE HAD ONE FAIL, IN FACT WE HAVE NEVER HAD ANY INTAKE GASKET FAIL
If you like them, then use them ... that is totally your prerogative. < I DO AND WILL
Other people, as well, are entitled to voice past issues; self caused, or not. < NEVER SAID TO ANYONE NOT TO VOICE A BAD ISSUE WITH THEM
Simply call Ford Performance Parts and ask them about the failures throughout the years on crate engines where they have had calls about separated intake gasket issues after a few years. THEN THEY ARE DOING SOMETHING WRONG
AGAIN, they have little control over how tight people make their intake bolts.< RIGHT
So, in essence ... you are one of the only people who know how to install them to have no issues; keep doing whatever you're doing.[/quote] <WE WILL
Look plenty of my guys have reinstalled an intake with 1231s after a cam change,or after an little oil seep( silicone) out the back after 3 or 4 years, still never a prob with the gasket it self. After using these gasket's for years, ( selling over 30+< not 100% sure of the num JUST THIS YEAR) And THOSE GUYS not having a prob either I'd have to say SOMEBODY IS DOING IT WRONG is all Im saying.
I mean come on execpt for on here I dont even know anyone who has has one fail . If none of mine, none of my guys, or the guys I sell to have had one fail Id say something else is wrong,and it needs looked over to what has happpened.
rmcomprandy wrote:BOSS 429 wrote:I CAN NOT BE THE ONLY ONE who knows how to install the 1231 intake gaskets, ALL the std layout port heads get thses gaskets, NEVER A FAIL,EVER. This is a great gasket.
Randy,X2 on your first paragraph I had that problem 3 or 4 different times with the CJ Port Gaskets didn't know they were using a steel Lamination in them now thanks for the info!! Although the last 3 or 4 times I've had my intake off I've used the Mr.Gasket Ultra Seals IIRC without any problems!!
Mark Miller- Posts : 1959
I mean come on execpt for on here I dont even know anyone who has has one fail . If none of mine, none of my guys, or the guys I sell to have had one fail Id say something else is wrong,and it needs looked over to what has happpened. [/quote]
Reread what Randy said he said they could have been overtightening the Intake bolts Hell maybe I was but I DID have PROBLEMS with them 3 or 4 different times Changed to MR.Gaskets no more problems tightening them the same way as with the Fel Pro Gaskets now Head Gaskets never any problems with the Fel Pro's!!
I’ve used fel pro for more times than I can count. I’ve never had a gasket nor work because of the gasket quality. I too have never heard anything bad about fel pro in general until I joined this site. I don’t get it. What are you guys doing to your gaskets today make them fail???? Victor Reinz are good also. I’ll never use mr. gasket valve cover gaskets again. You might as well not have a gasket at all.
stanger68- Posts : 502
I had a set of Fel-pro gaskets that did not seal 20 years back, the speedshop recommended the Ulta Seals, a very fine product, you can't judge the intake gasket by the vc gasket . That said, I never tried another set of Fel-pro gaskets on the intake again as far as I remember.
jpierce55- Posts : 111
Last edited by JBR-3 on October 17th 2020, 3:36 pm; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
JBR-3 wrote:What about using a thin film of grease on the blue print-o-seal "o-ring" so they wouldn't tear
when the intake is torqued down ?
How are you guys installing the print-o-seals so they work ?
X2 on your questions!!
ALL brand print-o-seal gaskets are not the same.
The Fel-Pro gaskets in question are Teflon coated on the print-o-seal side.
Simply tighten them SNUG ... don't over-torque them.
rmcomprandy wrote:JBR-3 wrote:What about using a thin film of grease on the blue print-o-seal "o-ring" so they wouldn't tear
» rebuilding a C6
» 521 Refresh questions
» i need to rebuild my 5.0
» 429 Fresh Rebuild
» 429 Rebuild questions
» 429 Fresh Rebuild
