557 BUILD
557 BUILD
HELLO I AM IN THE PROCESS OF HAVING A 557 STROKER BUILT BY A LOCAL SHOP AND I HAVE SOME QUESTIONS . I PLAN ON USING 1971 429 BLOCK EAGLE 557 ROTATING ASSEMBLY SCJ HEADS M6049-A A STEALTH CJ INTAKE AND A HYD ROLLER CAM . THE CAR IS VERY HEAVY AROUND 5000LBS AND WILL BE GEARED AROUND 3.23 TO 3.50 CARB AND CAM SPECS I HAVE NO IDEA ANY HELP AND OPINIONS WOULD BE APPRECIATED JUST SO I WILL KNOW IF IM HEADING IN THE RIGHT DIRECTION THANKS.
1971tjet- Posts : 18
Re: 557 BUILD
Comp 34-602-9 if you like a nasty idle or 34-443-9 the first will make mor power. Do a simple bowl and gain a bunch of power.
Re: 557 BUILD
Big 4150 carb 950 cfm 3500 converter
Re: 557 BUILD
1971tjet wrote:HELLO I AM IN THE PROCESS OF HAVING A 557 STROKER BUILT BY A LOCAL SHOP AND I HAVE SOME QUESTIONS . I PLAN ON USING 1971 429 BLOCK EAGLE 557 ROTATING ASSEMBLY SCJ HEADS M6049-A A STEALTH CJ INTAKE AND A HYD ROLLER CAM . THE CAR IS VERY HEAVY AROUND 5000LBS AND WILL BE GEARED AROUND 3.23 TO 3.50 CARB AND CAM SPECS I HAVE NO IDEA ANY HELP AND OPINIONS WOULD BE APPRECIATED JUST SO I WILL KNOW IF IM HEADING IN THE RIGHT DIRECTION THANKS.
In my opinion, I would not use a 429 block because of the shorter cylinders. I would use a later 460 block.
Re: 557 BUILD
What is this intended purpose? is this a cruiser, a drag racer, a 4x4 truck?
What fuel to use? pump gas, or race gas?
BBFTorino- Posts : 999
Re: 557 BUILD
ITS GOING INTO A 1971 TBIRD AND WILL BE PUMP GAS CRUISER , JUST WANNA MAKE SOME POWER AND HAVE A LITTLE FUN WITH IT
Re: 557 BUILD
ENGINE BUILDER WANTS TO USE THAT CAM ALSO 34-602-9
Re: 557 BUILD
THAT WAS ONE OF THE CAMS HE MENTIONED I MEANT ONE OF 3
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
» 460 build w/p51 heads build HELP!!
