Intake manifold
Intake manifold  Empty Intake manifold
Post  rivet November 16th 2019, 7:13 pm
What would be the best intake to use on a 466 with dove heads, cam?, high compression, single 4bbl, alcohol, in a pulling application (would prefer 4150 base)? Thanks for any input given.
rivet
Intake manifold  Empty Re: Intake manifold
Post  BBFTorino November 17th 2019, 12:45 am
Single plane high rise. Like an Edelbrock Victor, or a Mafia intake
Post  rmcomprandy November 17th 2019, 10:10 am
rivet wrote:What would be the best intake to use on a 466 with dove heads, cam?, high compression, single 4bbl, alcohol, in a pulling application (would prefer 4150 base)? Thanks for any input given.
With D0VE heads, the Trick Flow "Track Heat", (not the Victor or Mafia), would be most beneficial with those intake ports.
Post  rivet November 17th 2019, 6:52 pm
Thank you for the info. Will I have to do much grinding to get the ports lined up with the track heat? The heads are untouched in the port area.
rivet
Post  rmcomprandy November 17th 2019, 8:25 pm
rivet wrote:Thank you for the info. Will I have to do much grinding to get the ports lined up with the track heat?  The heads are untouched in the port area.
Not really ... that manifold is manufactured for use with the passenger car size ports.
Post  rivet November 18th 2019, 12:42 am
Thanks again for your help, I’ll have to get one of them and try it out.
rivet
Post  jpierce55 November 19th 2019, 3:07 pm
How would you view that intske vs an old ported port o sonic on a low rpm stroker, under 6k rpms?
jpierce55
Post  samiam November 19th 2019, 3:23 pm
I ran the Ford victor jr, with the dove heads on my puller for quite a while, had the A514 cam, and L2443 pistons, was a good hard pulling
combo
samiam
samiam
Post  rmcomprandy November 19th 2019, 6:22 pm
jpierce55 wrote:How would you view that intske vs an old ported port o sonic on a low rpm stroker, under 6k rpms?
No comparison ... the Port-O-Sonic, even ported, is not close anywhere in the power range.
The Port-O-Sonic won't match up well even against an Edelbrock "Torquer II".
Post  jpierce55 November 19th 2019, 7:43 pm
It might be a consideration once im ready to swap heads. How is it on height?
jpierce55
Post  rmcomprandy November 19th 2019, 8:00 pm
jpierce55 wrote:It might be a consideration once im ready to swap heads. How is it on height?
It is 6 3/4" tall; about a 1/2 inch taller than a Victor.
AGAIN, it has "passenger car" port location and size ports. TFS-53400111
Post  jpierce55 November 21st 2019, 10:49 am
I'll either swap to ported d3 or hopefully big chamber Edelbrocks once I get everything straight now. I don' t want to remove pistons for notching or get into raised exhaust ports....I need streetable compression, so not many options.l even if they aren't the best.
jpierce55
