Going 521 w/Blue Thunder 2x4
Mark O'Neal
the tree man
To maximize the potential of the ported SCJ heads I just got I've decided to upgrade to a 521 from 466 and will also be adding a custom,larger SFT cam from Cam Research.I'm really want to retain the current intake for appearance on the T-Bolt but curious if it will service the above combo.It's the small port version but I'll hog it out.On the 466 I'm running 2x600VS Holley which I think may be a bit small on a 521 but possibly not with this intake.Wondering if anybody has run this intake on the 500+ cube engines and what carbs?
the tree man- Posts : 124
Re: Going 521 w/Blue Thunder 2x4
the tree man wrote:To maximize the potential of the ported SCJ heads I just got I've decided to upgrade to a 521 from 466 and will also be adding a custom,larger SFT cam from Cam Research.I'm really want to retain the current intake for appearance on the T-Bolt but curious if it will service the above combo.It's the small port version but I'll hog it out.On the 466 I'm running 2x600VS Holley which I think may be a bit small on a 521 but possibly not with this intake.Wondering if anybody has run this intake on the 500+ cube engines and what carbs?
A.T. (Art) Francis at Blue Thunder offered both Standard port size and Cobra Jet port size dual-quad manifolds for the 385 series Ford big block engine.
I believe that only the ports were different for the last 2 inches and the actual flange heights were the same. This may have changed in later released manifolds but, I don't think so.
Just measure the height of the flange ... if it is tall enough then it will cover the taller SCJ ports.
That's correct.Lots of meat on this one at the port to match the CJ hole.When I bought this intake I could not find any dealers with a new one in stock and nobody,including Blue Thunder,seemed have a date when they would be available again so I spotted mine on Ebay and scored it.Another thing I noticed with this intake was a significantly wider swing in exhaust temps than the Ford Racing dual plane,single 4bbl that was on the motor initially.I wanted to try a couple open spacers to see if that would help with distribution but even with a 4" teardrop scoop the air cleaner is tight to the hood so they won't fit.If that would help with distribution I'd cut the divider in the intake a bit but I need to be sure before doing that.Anyone with thoughts on that?
the tree man wrote:That's correct.Lots of meat on this one at the port to match the CJ hole.When I bought this intake I could not find any dealers with a new one in stock and nobody,including Blue Thunder,seemed have a date when they would be available again so I spotted mine on Ebay and scored it.Another thing I noticed with this intake was a significantly wider swing in exhaust temps than the Ford Racing dual plane,single 4bbl that was on the motor initially.I wanted to try a couple open spacers to see if that would help with distribution but even with a 4" teardrop scoop the air cleaner is tight to the hood so they won't fit.If that would help with distribution I'd cut the divider in the intake a bit but I need to be sure before doing that.Anyone with thoughts on that?
That manifold, (as any 2 plane, dual quad, lower profile manifold), will never have good port to port distribution if ANY fuel is not fully atomized; especially at part throttles.
The carb flanges and under-bore radius' can be ported to get it a lot closer; (To detailed to even start directions here).
Other things which will make distribution closer is to mount the carbs backwards, similar to an FE Ford engine using a bellcrank for throttle actuation and making them actuate together, 1 to 1, not staged.
Thanks for that info.I read a couple posts where you had some experience with this intake and commented on it.I mounted my carbs conventionally for ease of throttle linkage and 1 to 1 but wondered if because the intake was based on the FE design that backwards may make a difference.A bunch of extra stuff was included with the intake when I purchased it including the reversed linkage so I'm going to spin them around and see what happens.Tuning the carbs also seemed fussier than usual even though it has a solid 11" of vacuum at 1000 rpm,I modified the Duraspark/6AL with a decent curve 22 at idle/36 all in at about 2000 and I'm running an AFR gauge so that cuts down on the guess work.I've had a number of dual quad set ups on street cars,love them,but on tunnel rams so this was new territory for me.I've reduced the IFR's about 25 percent and put jets in the metering plates but I also had to change powervalves,secondary springs,pump shot and cams,etc.Nothing went untouched yet I've always found the 2x4 600VS versatile and very forgiving.Any thoughts on sizing for the 521?Appreciate the input and any other suggestions.
the tree man wrote:Thanks for that info.I read a couple posts where you had some experience with this intake and commented on it.I mounted my carbs conventionally for ease of throttle linkage and 1 to 1 but wondered if because the intake was based on the FE design that backwards may make a difference.A bunch of extra stuff was included with the intake when I purchased it including the reversed linkage so I'm going to spin them around and see what happens.Tuning the carbs also seemed fussier than usual even though it has a solid 11" of vacuum at 1000 rpm,I modified the Duraspark/6AL with a decent curve 22 at idle/36 all in at about 2000 and I'm running an AFR gauge so that cuts down on the guess work.I've had a number of dual quad set ups on street cars,love them,but on tunnel rams so this was new territory for me.I've reduced the IFR's about 25 percent and put jets in the metering plates but I also had to change powervalves,secondary springs,pump shot and cams,etc.Nothing went untouched yet I've always found the 2x4 600VS versatile and very forgiving.Any thoughts on sizing for the 521?Appreciate the input and any other suggestions.
I have never used those manifolds on anything other than "street rod" type engines or Cobra kit cars maybe raced only once in a while; not anything for competition. Using 750 vacuum secondary or 660 center shooters or Carter/Edelbrock carbs have been my experience although 600cfm Vacuum Holleys should be fine for most anything.
Driveability and throttle response was really the only criteria. Carter/Edelbrock carbs seem to work fine forward but, a Holley or derivative seems to like being being reversed.
It's lots of fun,not fussy but still slightly fat at idle and has a very mild bog if you mash it without enough rpm (converter is a bit tight too);however,overall starts/idles/cruises fine and pulls pretty good,just not good enough.I'd like to see at least 620HP or more if possible.In your opinion,do you think that goal is attainable with the 521,ported SCJ's,SFT cam and this intake.Thanks again.
the tree man wrote:It's lots of fun,not fussy but still slightly fat at idle and has a very mild bog if you mash it without enough rpm (converter is a bit tight too);however,overall starts/idles/cruises fine and pulls pretty good,just not good enough.I'd like to see at least 620HP or more if possible.In your opinion,do you think that goal is attainable with the 521,ported SCJ's,SFT cam and this intake.Thanks again.
Easily ...
I Â use the BC/BD carbs (710 cfm 427 MR) on my 521 with early CJ aluminum heads.They were designed to run together on a dual plane intake so the calibration is good. I do run them backwards as Randy noted as that is how Ford ran them. Only the small blocks ran forward facing carbs.
Mine run very nicely no flat spots or stumbles. The linkage is still progressive but I will try the one to one next year at the track to see if the ET changes. I am comfortable that it makes over 600 hp on 91 octane.
gt350hr- Posts : 662
Thanks,boys.Good info to start.I sprung for these carbs new last winter,sizing them for the 466 assuming it would have enough HP.Pinhead,I know enough to know it's never enough.I'll fiddle with them for the time being.They are a smidge rich across the board as I have them set now so they might suit the extra demand of the new engine OK but I still feel they may be a bit small.Since another set will be about $1000 regardless what they are they'll have to wait.Looking forward to the extra HP/fun regardless.
Rich across the board makes sense as the "signal" ( vacuum pull) is greater on a larger CI engine and still pulling through the same size hole. That's the other reason I went with the 710's. Careful "shopping" can find them at reasonable prices like I did.
Ran the intake recently on a 572" P-51 headed engine. Certainly down on power vs. a good single 4bbl, but can make fair numbers. Fuel distribution is not perfect, but with a little work can certainly be made better.
Carbguy- Posts : 18
This is a street car so I'm not looking to set the world on fire.It will see at least a few thousand miles a summer and it's a Thunderbolt so the dual quads are mandatory.Car already has a built trans and diff but I don't want to go looking for the weakest link either so the 600+ range should be a good compromise between performance and reliability.A little extra bite to go with the bark.
What carbs did you run on that 572?
My Blue Thunder dual quad small port intake manifold flowed about 260 CFM with uneven distribution. When "The Mad Porter" was done porting said manifold, the CFM was about 315 and the distribution was much more even.
DanE- Posts : 90
I finally started tearing the Fairlane apart but before I disabled it I did the carb reversal experiment.I ran the car up to temp the way it is.Idle 1000,11" vacuum,AFR high 13 bumping 14,fuel screws out 1 1/2 turns,22* initial,1:1 linkage,dingbat EGT's.Pulled the carbs and turned them around.Took about 45 mins.It was still at 140* so it fired right up.Idle jumped to 1150,11.5" vacuum,AFR 15's.Turned idle down to 1000 and vacuum barely moved and AFR was still high so I opened the screws a 1/4 turn,14.5 AFR.The EGT's are way more consistent.The car actually ran better before with the screws at 1 3/4 but AFR would drop to low 13's and it would stink;however, light cruise and tip in felt better.Idle had decent chop to it before but even that seemed to mellow a bit.I'm surprised at the improvement.I almost blew this off over the pain in the arse throttle linkage.Moron.So thanks for giving me a push in the right direction.
If you get a chance, port the manifold. Try to get rid of the sharp 90 degree turns at the bottom of of the carb pads. Be willing to mill those dividers down a little bit. Maybe just .250" to .375" of an inch. We've got one here, the bigger CJ version, and I have done some flow testing with it. Your most beneficial work will be in the carb pad area, where we normally have a carb plenum in race manifolds, we don't with the 2x4 manifold.
c.evans- BBF VENDOR SPONSOR
Thanks! I never really looked that closely at this intake before installing it but after seeing the improvement from just reversing the carbs I'll be nosing around in there a lot more when I start grinding the ports to the CJ size.I considered reducing the dividers below the carb about the amount you suggested but more to help with the idle/low rpm fuel distribution.I don't think the engine would even notice a 1/4" gap once the air really gets moving unlike cutting 1" out of the divider in a 2 hole dual plane intake.Is this correct or does it help up the range also?
the tree man wrote:Thanks! I never really looked that closely at this intake before installing it but after seeing the improvement from just reversing the carbs I'll be nosing around in there a lot more when I start grinding the ports to the CJ size.I considered reducing the dividers below the carb about the amount you suggested but more to help with the idle/low rpm fuel distribution.I don't think the engine would even notice a 1/4" gap once the air really gets moving unlike cutting 1" out of the divider in a 2 hole dual plane intake.Is this correct or does it help up the range also?
The diagonal walls, separating the primary bore from the secondary bore under the carbs, on the upper runners should be removed completely; sort of making a slanted figure 8.
Interesting. I think I know what you mean.I believe there was an FE low or medium riser intake that looked like that?Possibly the one Blue Thunder used to pattern the 429/460 intake.I'll have to search that out.
This kind of thing? Small block Chev. Sorry.
https://www.ebay.ca/itm/AWESOME-HIGH-PERFORMANCE-WEIAND-DUAL-QUAD-INTAKE-MANIFOLD-LOOK/202672850491?hash=item2f303e463b:g:IIIAAOSwmE9cQoNG&vxp=mtr
the tree man wrote:This kind of thing? Small block Chev. Sorry.
YES ... just like that.
» Blue Thunder 100 cc's
» Need help with Blue Thunder
» Can anyone I.D. this 429-460 2 x 4 manifold ?
» Here's a little porn for you guys !!!!
» billet main cap question
