billet main cap question
Has anyone used the front or rear billet main caps from pro-gram or blue thunder? I'm adding splayed caps to the center 3 on a d1ve block and wanted to know has anybody else used the outer caps and how did it work out. I'm going to line bore/hone anyway so this won't really add much to the cost, if I'm going to do it, nows the time. Any feedback at all would be appreciated. Thanks, Greg
blown473- Posts : 376
Re: billet main cap question
I've used the blue thunders caps on all 5 mains and would recomend the front 4 bolt cap with pin but save some money and just use the stock rear cap if yours registers tight and has not had cap walk problems. The blue thunder rear cap is billet but it is just a 2 bolt cap which requires a bit of machine work to get it installed.
I may have some pics of that block -( before & after machining) on a old computer if you need some visual perspective.
STEVE
STEVE
BIGINCH'S- Posts : 31
main cap/blue thunder
Thanks for the reply. I did not know blue thunders front cap was a 4 bolt cap; their web site has no pictures of their products. Pro-grams is billet but only a 2 bolt cap, rear is same as blue thunder. This is why this forum is so valuable, I just gained some important information, Thank you! I run a blower so the front cap get extra stress from the 3" belt tugging on it so a 4 bolt cap has a big appeal.
Front is 4 bolt and pinned as well on that one.
If your gonna put caps on and your running a blower then go with the front cap for sure.
STEVE
STEVE
Caps
Thanks biginche's , appreciate the info. I've been running an 871 on a 2 bolt block with a main girdle and arp studs for about 6+ years with no issues but I'm stepping up from 473 cid to 545 and want to add some strength to the new motor. I've got Blue thunder heads so I've used their products and like them, so I will order up the front cap from them.
program main caps
yes I have used the program front and rear caps...nice parts,fit and worked very well..brian
birdracer- Posts : 42
Thanks Brian aka Birdracer
Thanks for the reply. Pro-grams web site has good pictures they look like a top quality billet product, and the prices are very competitive. I wish Blue thunder had a better site, only pics for some items. Some companys now how to make a great product, but don't market them very well. Seeing and then touching are the keys to a sale. ( manufacturers/retailers listening? thats free advise from decades of selling the stuff!) Paul Kane and Lem Evans are experts at this they both post pictures so detailed you want those parts now! (And the fact they sell the best stuff-no junk!) I'm a little off topic here but I want to say Thanks to everybody here on the forum for the help to fill in the blanks on product or use questions and to the parts retailers here who not only help with good advise, but keep us in quality parts as well. Thank you all Greg blown473
» Main Bearing Question
» milodon 4 bolt main caps question.
» Question about Milodon 4bolt main caps
» Main cap bolt question... installing M-6675-A460 oil pan
» 4 bolt main conversion? Or 2 bolt main stud girdle?
