Cracked Engine Block
Re: Cracked Engine Block
Welding changes the properties of the cast iron making it brittle and thereby even more prone to cracking, especially in a load-bearing location such as you have. The change in the cast iron's properties from the welding is known as "graphitization."
You are better off stitching it with a Castmaster-style thread insert from Lock-n-Stitch. That type of repair will be stronger than the original cast iron, even with the crack still being there untouched. I would suggest their "Full Torque Flush Blind" inserts, but really you should contact them directly with the same picture you posted here, including the thread size and the width of the main webbing at that location, and ask for their recommendation.
http://www.locknstitch.com/index.html
nascar429 likes this post
» A460 block with cracked main cap
» Cracked Premier IDT Eliminator Block
» cooling system size for 578 - cracked A460 block after all
» Engine block class limitation
» I need some help identifying an engine block
