Early fms a460 head?
lance flake
Best I can find early a460 heads came bare with no valves. Does anybody have any info on the intake/exhaust runner cc as cast? Maybe some port/bowl measurements? I have and early set I'm working on that are not impressive on the flow bench and just trying to get some basic info on them.
lance flake- Posts : 142
Re: Early fms a460 head?
I believe they are cast as 340 cc intake runners
BBFTorino- Posts : 998
BBFTorino wrote:I believe they are cast as 340 cc intake runners
Thanks!
The current TFS 340cc head's intake runners are bigger than the Ford A460 heads.
I will do some measuring this weekend on these heads. Just haven't seen many for comparison on what has been done to them. They still have a 2.3 valve in them.
Lem Evans wrote:The current TFS 340cc head's intake runners are bigger than the Ford A460 heads.
YES ... The FMS heads have considerably smaller cross sectional area in the intake ports than the later TFS heads have.
rmcomprandy wrote:Lem Evans wrote:The current TFS 340cc head's intake runners are bigger than the Ford A460 heads.
Yep, the old heads didn't flow well as delivered.
Do you have any idea what the average/min cross section is as cast? I am going to try to get time this weekend to measure up everything. Thanks for the help!!
I don’t know the cross section on them but my first set of A heads were small in comparison to the tfs I got a few years ago. I had done quite a bit of porting on them but stayed off the short turn. It didn’t run all that good and didn’t respond to changes I made And later when I had I’d down I flowed one and as some here had guessed they sucked! Lol. 360cfm ! More bowl work and very little short turn got 425cfm with the 2.3 valves.
The early FMS A-460 heads respond well to a lot of help on the short side turn /radius.
c.evans- BBF VENDOR SPONSOR
» meziere pump ,A460 head studs,new style A460 intake
» Early a460 block and 4.75 crank
» which a460 head for me?
» A460 head
» A460 head 528
» A460 head
» A460 head 528
