A460 Head Question
A460 Head Question
Is the intake and exhaust valve angle within 2 degrees of oem valve angle? Class rules mandate oem valve angle +- 2 degrees. Thanks for the help.
wreckless4thf- Posts : 47
Re: A460 Head Question
A460
I = 13 x 5.2
E = 9.5 x 5.2
P-51
I = 8.3 x 4.7
E 4.0 x 3.2
Factory
I = 14.5 x 5
E = 15 x 4
Sounds like your dealing with Chevy Rules or should I say rules to favor Chevy's.....
I = 13 x 5.2
E = 9.5 x 5.2
P-51
I = 8.3 x 4.7
E 4.0 x 3.2
Factory
I = 14.5 x 5
E = 15 x 4
Last edited by dfree383 on July 1st 2010, 3:32 pm; edited 2 times in total (Reason for editing : Randy's correction)
dfree383 wrote:A460
I = 13 x 5.2
E = 9.5 x 5.2
P-51
I = 8.3 x 4.7
E 4.0 x 3.2
Factory
I = 9.5 x 5
E = 15 x 4
I don't understand the 9.5 X 5 stuff. Does this mean in layman's terms it's 9.5 degree on the intake and 15 degree on the exhaust?
Yes, if you put it in Chevy Terms.
dfree383 wrote:Yes, if you put it in Chevy Terms.
Thanks, looks like I will get kicked out of the class then lol. There checking valve angles next race.
For arguments sake do you know what the factory valve angle on a BB Chebby is?
???? 24 Degree ??? x ?????
How are they planning on checking them? Have the outlined a method?
dfree383 wrote:???? 24 Degree ??? x ?????
They said we need to have a valve cover off and they have some device that will measure angle off of the retainer and valve stem. Said we would understand it when we saw it lol.
I'd ask them for a listing of valve angles prior to going.
Origional Equipment Mfg....... are the Ford Motorsport Aheads?? They are O.E.M......... and you haven't changed the Valve Angles they come with right?
The production BBF iron head intake valve has a 14.5° incline valve angle not 9.5° angle.
I think a "Cleveland" intake valve might be 9.5° but, I'm not sure.
The big block Chevy Production intake angle is 26°.
IF they only check the INTAKE valve angle, the A460 head will pass inspection; the exhaust valve angle is more than 2° different however.
rmcomprandy wrote:The production BBF iron head intake valve has a 14.5° incline valve angle not 9.5° angle.
So the exhaust angles quoted are correct?
make it easier to check the intake ---- dont ask me how to do that now, LOL --- if they give you a hard time i'd argue its the intake valve making the power and the exhaust dont matter type of stuff. hard to believe with car counts like they are at most places these days they would even dare to check.
RGL- Posts : 27
» A460 cylinder head question
» A460 head pushrod question
» A460 head
» question on compression ...using pump gas (a460...using fms a460 heads)
» Question about TFS A460 and Motorsport A460 heads
» A460 head
