Question about TFS A460 and Motorsport A460 heads
I currently have a set of Ford Motorsport heads. I'm thinking of ordering the TFS A460 340 bare heads. I was curious if could I use the valves and springs off of the motorsport heads on the new TFS heads. I was told from a friend that the valves may not work for some reason, can anyone help with this topic?
chadb- Posts : 3
Re: Question about TFS A460 and Motorsport A460 heads
chadb wrote:I currently have a set of Ford Motorsport heads. I'm thinking of ordering the TFS A460 340 bare heads. I was curious if could I use the valves and springs off of the motorsport heads on the new TFS heads. I was told from a friend that the valves may not work for some reason, can anyone help with this topic?
Depends upon what TFS options you get with the castings. Some will interchange.
TFS-5441B001-M87
This is the part number of the TFS heads I would be getting.
chadb- Posts : 3
chadb wrote:TFS-5441B001-M87
You should be able to install the A460 Motorsport valves and springs into those heads; (although the Motorsport exhaust valves are a tulip design).
Depends on what you actually have in the Motorsport heads
why are you changing the heads anyway?
NITROUS FORD- Posts : 63
Getting new heads simply to update my operation. Have been looking at getting new heads for a few years now. Decided to go with the assembled TFS heads and be done with it. Thanks for everyone's input.
chadb- Posts : 3
Just a question as to the goals of changing the heads... raised ports, bigger valves I get it, but are the assembled heads going to give you the right matched components for the camshaft you want to maximize the combination and meet your expectations?
FalconEh- Posts : 1448
» C460 Heads and A460 Block question
» Motorsport A460
» need answers please ,, just got some motorsport a 460 heads and have question on my block also
» question on compression ...using pump gas (a460...using fms a460 heads)
» Ford Motorsport A460 Heads Reworked with a major issue
» Motorsport A460
