C460 Heads and A460 Block question
I am looking to see what diameter push rods people are use on the C460 heads. I have T &D rockers and offset intake Crower lifters. Mine are currently 3/8" and looking to see what lager diameter will fit without getting into the intake port. Also I have an older A460 block that is 10 bolt and was to wanting to see if anyone has converted one to 18 bolt or if could be done. Any information would be great.
Michael Remines
Michael Remines
Remines- Posts : 22
Re: C460 Heads and A460 Block question
Remines wrote:I am looking to see what diameter push rods people are use on the C460 heads. I have T &D rockers and offset intake Crower lifters. Mine are currently 3/8" and looking to see what lager diameter will fit without getting into the intake port. Also I have an older A460 block that is 10 bolt and was to wanting to see if anyone has converted one to 18 bolt or if could be done. Any information would be great.
Michael Remines
Both 3/8 and 7/16" are used. You will not have to mill/grind on the head as much to get the 3/8 in there.
I've not used the T&D but, the Jesel are easier to get the pushrods in than the WW. Use a ~.135" wall if you use the 3/8".
Michael Remines
The major need for a larger diameter pushrod is usually on the exhaust side as that valve is opening against a lot more pressure in the cylinder.
rmcomprandy wrote:Remines wrote:I am looking to see what diameter push rods people are use on the C460 heads. I have T &D rockers and offset intake Crower lifters. Mine are currently 3/8" and looking to see what lager diameter will fit without getting into the intake port. Also I have an older A460 block that is 10 bolt and was to wanting to see if anyone has converted one to 18 bolt or if could be done. Any information would be great.
Michael Remines
For sure and I'm working on a project now that will have a 3/8" .135" wall intake rod and a 7/16" .165" wall exhaust rod. About the same price for both rods so why not. Good point , Randy.
Thanks guys for the replies. I have a couple of 7/16 .165 ordered for mock up to see what kind of clean up is needed. Does anyone have any information to share with the possibility of machining the block for the extra head bolt hole? Thanks again for all of the experienced information.
Michael Remines
Michael Remines
Remines- Posts : 22
Remines wrote:Thanks guys for the replies. I have a couple of 7/16 .165 ordered for mock up to see what kind of clean up is needed. Does anyone have any information to share with the possibility of machining the block for the extra head bolt hole? Thanks again for all of the experienced information.
Michael Remines
Unless it is a really early block; today's A460 blocks are already machined for those head bolts.
The outside, (exhaust side), extra locations would be rather easy to drill and tap on early blocks.
[quote="Remines"]Thanks guys for the replies. I have a couple of 7/16 .165 ordered for mock up to see what kind of clean up is needed. Does anyone have any information to share with the possibility of machining the block for the extra head bolt hole? Thanks again for all of the experienced information.
Michael Remines [/quote
If the lugs are in the valley for the inner studs or bolts, be advised that they are at a 7.5* angle to the deck surface. In other words the are laid in an upward direction towards the bottom of the intake manifold off of perpendicular to the deck surface. That means that the underside of the lug gets broached at 52.5* (45* +7.5*) in order for the washer and nut, or bolt head to set square. Also this 7/16" hole does not have to be round, but can be somewhat slotted or elongated.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Thanks to all for the information. This is very helpful.
Michael Remines
Michael Remines
Remines- Posts : 22
» a460 or c460 heads
» Charlie Evans...a question on a460 TR to c460 adapters..
» question on compression ...using pump gas (a460...using fms a460 heads)
» C460 Heads and Intake Question
