Charlie Evans...a question on a460 TR to c460 adapters..
Charlie how much of an effect do you believe the port roof height difference makes in the real world?..I used .125" a460 gaskets and raised the manifold as much as I could..A pretty nice transition was able to be made with porting the adapters and intake..I have ran across some pretty ugly intake to head mismatches that ran pretty good.just curious on your thoughts...Thanks for your help..Brian W
birdracer- Posts : 42
Re: Charlie Evans...a question on a460 TR to c460 adapters..
![pirat](https://2img.net/i/fa/i/smiles/icon_pirat.png)
Curt- Posts : 2790
Brian,
I am glad you took your time and did it right. I do think it is very important to have a good match between the intake and the heads. Like you, I have seen some pretty ugly stuff before. As you look down those A-460 runners into the C-460 intake ports you are seeking a best compromise position when comparing the roof to the roof, and the floor to the floor. All you can do with the manifold is raise it or lower it as needed, for sure you can't go forward or backwards. I use the four very corner vertical bolt holes, as "line-up" pins and put long studs in those holes.
Curt,
Yes, Terry Conolty bugged me about using O-rings around the ports. I told him if he wanted to o-ring them to go ahead and do it himself. They did. The intake ports don't leak,,,,,but I think now they have had some leaking around the water jacket holes. So TA31 and gaskets work fine for me.
Charlie
Curt,
![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png)
Charlie
c.evans- BBF VENDOR SPONSOR
If you like it, I love it. Thanks
![I love you](https://2img.net/i/fa/i/smiles/herz.png)
Curt- Posts : 2790
Thanks Charlie..there was more difference at the roof than the floors,just couldnt get the manifold any higher or the a460 ports taller,no material on the manifold..but I don't feel from what I know that any big loss will be seen..this thing should make at least 300 hp!
![Laughing](https://2img.net/i/fa/i/smiles/icon_lol.gif)
» Distributor...will this one work with my intake?
» Charlie Evans HEader collector Question
» Best distributor for Evans A460 TR intake adapted to C460 heads?
» C460 Heads and A460 Block question
» Charlie Evans, thanks.
