Best distributor for Evans A460 TR intake adapted to C460 heads?
birdracer
Best distributor for Evans A460 TR intake adapted to C460 heads? Empty Best distributor for Evans A460 TR intake adapted to C460 heads?
Post  birdracer December 15th 2010, 12:12 pm
what have you fellows used for Distributor and cap and rotor set ups with the t-ram and adapter plates..I have the 3 9/16 distributor and a small cap works,but have you a favorite cap/wire combo here? thank you ,Brian
birdracer
Best distributor for Evans A460 TR intake adapted to C460 heads? Empty Re: Best distributor for Evans A460 TR intake adapted to C460 heads?
Post  c.evans December 15th 2010, 12:33 pm
Brian,
I used to use the Blue Streak cap and rotor,(1957-73) which was the high performance stuff with copper terminals made by Standard Ignition. However, my local Adavnce Auto Parts store quit carrying Blue Streak. So now I just buy the Summit brand cap & rotor set , which is blue in color and has the copper terminals that I prefer. Then I just use the old socket style blue spark plug wire kit from Ford Racing (Lem).
It always helps to grind some of the bottom front corner off of the TFS tunnel ram plenum, it's real thick anyway, but I grind it off at about a 30* angle in order to make some room to R&R the cap.
Hope this helps,
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Curt December 15th 2010, 12:39 pm
here is a couple pictures of mine that Bob laid out.
Best distributor for Evans A460 TR intake adapted to C460 heads? Newbuild25
Best distributor for Evans A460 TR intake adapted to C460 heads? Newbuild30
Post  jones December 15th 2010, 1:22 pm
Is that the factory distrubutor?
Charlie are you still selling the crab cap adaptor?
jones
Post  Curt December 15th 2010, 2:04 pm
Not sure, you'll have to ask Charlie. I havent seen it yet. Flip may know.
I do think he still sells the conversion and crap cap for the Ford distributor
Post  jones December 15th 2010, 3:04 pm
Sure is pretty!
jones
Post  Curt December 15th 2010, 4:12 pm
Thanks, I hope to get to meet it in person here in a couple of weeks. I love you
Post  birdracer December 15th 2010, 4:16 pm
Thanks Kurt for the pics....thats a handsome engine for sure..Charlie...as always I appreciate your wisdom and help on this build.It is going to run soon,just closing up the small details..will let you know what the dyno numbers are,no matter how embarrassing they may be!..Brian
birdracer
Post  c.evans December 15th 2010, 5:30 pm
Guys,
With the A-460 manifold to C-460 head adapters, you can use the factory 429-460 distributor which measures 3 and 9/16" fron the cap surface to block mounting surface. I aways take 2 or 3 junkyard distributors and use the best parts I find to build one. I also replace the magnetic pick-up and the star wheel with new Borg-Warner parts. In fact they also sell the sintered bronze bushings for the dist. housing in Borg-Warner catalog. I like the Motorcraft housings better than the Autolite housings. Because the manifold is setting up higher, you can use the old style small cap (1957-1973) on your distributor.
With the TFS A-460 tunnel ram on A-460 heads, they designed it thinking everybody would use an MSD crank trigger and low profile MSD distributor. However, if you want to run a factory 429-460 Ford distributor you can, by using one of my alum. billet cap adapters and the Mallory #221 crap cap. Again it helps to do some grinding on the underneath side and front bottom corner of the plenum of the manifold for cap clearance.
MSD uses the same guts as the factory Ford stuff, meaning the magnetic pick-up and the star wheel, so of course we can just use the Ford Motorcraft distributor to trigger the MSD box/ignition. The black wire with a purple tracer coming out of the distributor connects to the green wire in the MSD harness connector, NOT the purple wire.
Hope this helps,
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  '65 T-BOLT December 15th 2010, 11:04 pm
Cuirt...I met your engine! I was caught red handed by JBB..I was gonna load it up in the back of the rental car and bring it to Maryland...Just wouldn't fit...
'65 T-BOLT
'65 T-BOLT
Post  Curt December 16th 2010, 10:10 am
Whew, glad to hear it didn't head farther North and East! LOL Hope the weather will be nice enought to put the rig on the road. We are headed to NYC today, hope with don't get snowed in for the winter. santa
Best distributor for Evans A460 TR intake adapted to C460 heads? 7032
Post  bbf-falcon December 16th 2010, 11:06 am
Best distributor for Evans A460 TR intake adapted to C460 heads? IMG_0724
