need answers please ,, just got some motorsport a 460 heads and have question on my block also
question # 1 .......my heads are motorsport a 460 ......i want to use on my d1ve block ( i know you guys are gonna say why ,...but i am)
what head studs do i use for these heads on my block ?
question # 2 .........these are 7/16 push rods? and 3/8 rocker studs correct ?
last question ...............on my d1ve block have partial fill and main caps installed ......ive heard the cylinders are shorter ....i got 6.8 oliver rods and gonna get a crank but un sure of doing a 4.3 or 4.5 in my block .........any help would be great ...
gonna do either 521 or 545 .030 over and yes my valves will be shrouded i know
thanks ....always good tech here
5pointslow- Posts : 1408
Re: need answers please ,, just got some motorsport a 460 heads and have question on my block also
5pointslow wrote:question # 1 .......my heads are motorsport a 460 ......i want to use on my d1ve block ( i know you guys are gonna say why ,...but i am)
#1 Use A-460 head studs.
#2 Most likely they are 3/8" pushrods and 7/16" rocker studs. Typo on your part?
#3 Yes, they D1VE block has the short cylinder walls. I have used both the 4.300 stroke and the 4.500 stroke crankshafts in short cylinder wall blocks. 4.300" is technically "more better" because it does not pull the pin down so far out of the cylinder bore. Main thing is, make sure and hand sand or champher the bottom of the cylinders so that there are no sharp corners.
#4 In regards to your shrouding, check your exhaust valve clearance carefully. Most of the older Motorsports A-460 heads used either a 1.940" diamter or a 1.900" diameter exhaust valve. Most likely they will hit the cylinder wall (.030" over) as they open.
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
» WTB: Used intake for original AR/Motorsport A441 hemi heads on 11.2" deck height block
» *SOLD* 632 All-Aluminum Engine - C460 Heads, RDI Motorsport Block, CFE Intake, 3 Nitrous Kits
» C460 Heads and A460 Block question
» Question about TFS A460 and Motorsport A460 heads
» Kaase pump canton pan...issue
