Modified Tunnel ram
Modified Tunnel ram Empty Modified Tunnel ram
Post  Ed1851 January 13th 2020, 12:06 am
Modified Tunnel ram 20200110
Modified Tunnel ram 20200111
Has anybody see these modifications and is it worth?
Somebody's put a ton of work on it.
I have had it for years and it works pretty good
Ed1851
Modified Tunnel ram Empty Looks to me like
Post  57ford custom January 19th 2020, 4:00 pm
the bottom of top part was machined off and the top welded back on. Am i right? Boy it sure is polished up very nice. Smile In effect shortening it or lowering it some.
57ford custom
57ford custom
Modified Tunnel ram Empty Re: Modified Tunnel ram
Post  jasonf January 19th 2020, 10:05 pm
What does the top/inside look like? Freelander and Blake the Snake have/had modified tunnel rams in a similar fashion. It's hard to tell if the top of the runner has been modded but that's usually where the biggest change is.
Post  Ed1851 January 19th 2020, 11:38 pm
Here's a topside view
Modified Tunnel ram 20200115
I hope it works, still figuring out pics
Ed1851
Modified Tunnel ram Empty tunnel ram
Post  57ford custom January 20th 2020, 12:09 am
Can you take a measurment to see how much milled off either the top piece or the bottom? I was going to make a fabricated  top for mine but this looks very very interesting. This last summer I took my tunnel ram off of my 523 which has a best so far of 10:50 at 128. I had 2 inch risers and 750 cfm single fuel inlet Holleys on it too facing as I refer to it as north and south. It stuck up to far out of the hood for my liking so I bought a "dare I say it (speedmaster) manifold that has a adapter from blower to dual carbs I didn't get a chance to run this setup as it was the last of the season and it got cold and wet. But I did take it out on the highway near my house and did 2 launches. One from a dead stop and one from about 40mph. Strangely enough it felt really strong in fact the 40 mph rolling start it broke loose and I had to back off. With the tunnel ram and carb spacers on it I have used a pair of Edelbrock 750's and switched to the Holleys and it was kind of a tie both about 128 and right near 10:50. The car weighs with me in it slightly over 3600 lbs.
57ford custom
57ford custom
