heads what are they worth?
biglucky
gt350hr
Rickytx630
not sure where to post this but looking to get an idea of what a set of A429 cj heads are worth, should be planned,
and also what would a set of p51 heads be worth? both heads set up for roller cam, triple springs. moving on and not gonna need the cj heads for sure the p51s are possibly going up as well just trying to get an idea
Rickytx630- Posts : 100
Re: heads what are they worth?
Why aren't you happy with the P-51's?
Mike R- Posts : 1381
Mike R wrote:Why aren't you happy with the P-51's?
pretty sure i lost the converter so im not giving up completely on the p51s
car just seem not to run and pull like it should or was, only thing that changed in the combo was the pistons, and the heads and pushrods ( cj A429s i ran a je piston, and when the p51s i went to a diamond racing piston) the car used to pullhard but seem to pull its best from the 660' on or back half of the track,
with the 5 runs i have on the p51s i dont get the pull feeling and its spinning more rpms but slowed down,
i also went from running 32* of timing to 28* as suggested with the p51s, idk if maybe the timing has something to do with it, i pulled the motor apart, cam still looks great and new, lifters are good, pushrods are straight nothing seems to be binding, even pulled the meatball out checked gears and axles which were good and put new rear slicks on it, it was getting faster every pass in the 5 i made but thee car has slowed a good 2 tenths.
so gonna try the new converter in the spring and really hope that was my issue, but im ready to start over and fresh with everything
I've seen them for as little as $650 (stock , used needing freshening) to the set I bought a while back ( fresh , ported , surfaced , ti retainers)for $1200. What are you going to ask?
gt350hr- Posts : 662
You have convertor issues.
biglucky- Posts : 213
Converter, or a big change in the weather.
BBFTorino- Posts : 997
ive to a 95% answer its the converter,biglucky wrote:You have convertor issues.
i got a new one bought it as a christmas present for myself, just waiting for the weather to break
Same camshaft that was used with the A429 heads?
With the much, much better mid lift flow of the P51 heads the camshaft requirement will be very different than with the A429 head - in my opinion.
Good luck with the new converter too!
68galaxie- Posts : 351
Just hold off on selling the P-51 heads. I really think it's your converter. I've seen times when newly gained power just fried the old converter.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Logic says that if you're turning higher RPM, but the ET has slowed 2 tenths, the heads can't be to blame - something is getting looser/failing (converter?) than it was. Just wait until you try the new converter.
pmrphil- Posts : 170
» iron D3 heads worth anything ? i have 4 sets was thinking of scrapping them
» Wtb Boss 429 heads
» Are these heads worth swapping to my engine?
» F460 iron heads worth it?
» Whats a pair of stock D2OE-AB PI heads worth?
