F460 iron heads worth it?
Are the F460 heads worth the money over fully ported DOVE heads? F460 heads have not been ported yet. It’s going on 557 race engine. I’m limited to iron heads in my drag race class.
pigs521bbf- Posts : 173
Re: F460 iron heads worth it?
Yes, the F-460 heads will be worth it. Essentially they are a crossbred between a regular CJ iron combustion chamber and A-460 ports. They will require a lot of porting. There's multiple /optional intake manifold bolt hole locations. You have to figure out what you have.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Charlie,
Is it better to go with EX 514 heads instead? Or going with the f460 head due to the stock valve placement?
pigs521bbf wrote:Charlie,
The EX heads, (if you can get a pair), are better for making power however, it really depends upon what your rules will allow.
A lot of associations don't allow them.
I agree with Randy. The EX514 iron heads are a true A-460 head and have better valve pierce point locations.
Charlie
Charlie
But if I cannot find a set of EX 514, a set of F460 heads ported will perform better than a fully ported DOVE on my 557?
Couldn't figure out how to copy the link on my phone here but go to the proven builds section and there is a sticky there with a lot of good data on cylinder heads. Well worth the read.
stanger68- Posts : 499
» iron D3 heads worth anything ? i have 4 sets was thinking of scrapping them
» Are these heads worth swapping to my engine?
» heads what are they worth?
» Iron Head Specialists ???
