Broken dowel pin in timing gear
MarkJ
pmrphil
airford1
Decide to freshen up my engine and the cam/timing gear had a broken dowel pin. Single pin broke in 3 pieces with one piece still recessed in the cam. Can anyone tell me why this happens? I guess I will have to drill in out of the cam to save that.
airford1- Posts : 192
Re: Broken dowel pin in timing gear
3/8 bolt or 7/16? I would think not quite enough clamp load, or the bolt got loose. I've done a few with double pins.
pmrphil- Posts : 171
Phil do you do engine at your shop?
Very lucky
I wish I had your luck. That was the first thing that got me when switching from small block in 88. My single pin broke at the top of low gear. It took out every valve and push rod, fortunately the cam and lifters were good. Since then I always double pin them, suggest you do the same. Mark J
MarkJ- Posts : 17
Yes sir. The 3/8-16 cam bolt doesn't (I believe) provide enough clamping force for an aggressive roller. The 7/16-20 is a good option, but double pinning will prevent breakage.
Dont know how lucky I am. I thought I was ready to go racing and noticed the water was low in the radiator with nothing in the overflow. Bingo the oil had a discoloration and was high. Water in the oil and it's not a head gasket. I may be lucky if I only have to polish the crank , new bearings and re ring. I think the water came from the intake gasket being crushed with RTV compound letting it deform the felpro slip all over.MarkJ wrote:I wish I had your luck. That was the first thing that got me when switching from small block in 88. My single pin broke at the top of low gear. It took out every valve and push rod, fortunately the cam and lifters were good. Since then I always double pin them, suggest you do the same. Mark J
Trick of the week
In an effort to make you feel better, at least you were not wheels in the air pulling second gear at just the moment you ran over your oil filter. Kicked a rod thru the svo block, putting 15 quarts of valvoline on the track. I shut the track down for a while. I am sitting in the trailer pondering getting a junk yard engine just so I can race when one of the track guys brings me my rod bolt with the threads from the trick of the week aluminum billet rod still in it. Should have stayed with howard rods and I would still be running that combo. Moral of the story, let someone else try out tge trick of the week. Mark J
MarkJ- Posts : 17
pmrphil wrote:Yes sir. The 3/8-16 cam bolt doesn't (I believe) provide enough clamping force for an aggressive roller. The 7/16-20 is a good option, but double pinning will prevent breakage.
Even double pins will shear if the bolt torque is not enough and valve spring pressure is high.
Personally, I will only use roller cams having 7/16-20 threads and then use a rod bolt that torques to 90 foot pounds for retention. Be sure to use a thick, hardened washer, like an ARP 200-8717, too; (a one piece FE eccentric works well, also).
[quote="airford1"]
Those junk Felpro gaskets . I went to Victor Reinz Intake gaskets many years ago now and haven't touched since ..
MarkJ wrote: I think the water came from the intake gasket being crushed with RTV compound letting it deform the felpro slip all over.
Gregaust- Posts : 625
rmcomprandy wrote:pmrphil wrote:Yes sir. The 3/8-16 cam bolt doesn't (I believe) provide enough clamping force for an aggressive roller. The 7/16-20 is a good option, but double pinning will prevent breakage.
This is same as the SBC crankshaft end bolt and washer. I feel better with a little loctite on the threads.
Dave De- Posts : 797
I second Randy M's comment.
We did a Boss 345 deal not too long ago with an XM HR grind, double pinned and no FP eccentric. A two piece fuel pump eccentric didn't help.
Without a 1 piece eccentric the flimsy ARP washer included in the 1001 bolt kit was deflecting and would not apply the necessary clamping pressure to keep the cam gear from moving ever so slightly.
In this particular case a thick larger diameter washer from a SBF finishing kit and the ARP bolt solved the problem with or with out an eccentric.
The heavy washer from an FE finishing kit works well for the SR and HR cams that require the 7/16" NF bolt.
That ARP washer is SO from our local supplier EPWI
Good info Randy. Thanxx.
SJ
used 2b RHP
SJ
used 2b RHP
» 521 cid broken camshaft dowel for timing gear . bent valves
» Advance Cam or Not ?
» Broken timing chain
» Timing Gear/cam retaining bolt
» which timing gear?
