Rotor phase kit
Rotor phase kit
Is there a rotor phase kit that works with the 8408 cap or 8580 distributor?
jpierce55- Posts : 111
Re: Rotor phase kit
MSD 8421
I believe this is the one I used with my MSD 8580 distributor.
https://www.holley.com/products/ignition/distributors/distributor_accessories/distributor_caps_and_rotors/parts/8421
68galaxie- Posts : 351
Re: Rotor phase kit
That is the one I was thinking, but searched and could not find the pn actually listed. Thanks.
I have fp and starter issues. I will be wiring my ignition to an oil pressure switch, but also want to check this. It was also recommended I data log the vdrop at the starter while cranking. Hope its not that since I just rewired it all, may just add a 2nd battery if so. I am trying to cover all bases!
Re: Rotor phase kit
You were correct . I have been sick the last 2 weekends. I need to recover so I can take another crack at it.
I have a used 1 time 8423 rotor now...lol. I need to sell a few items this spring.
» Starter shim or weak battery?
» Rotor Phase on BBF with no crank trigger?
» Need help engine quit firing
» Starting the design phase of my Stock Eliminator 1974 460 w/Thermoquad setup
» rotor phasing?
» rotor phasing?
