Hydraulic roller cam
Hydraulic roller cam Empty Hydraulic roller cam
Post  sledhead1 March 14th 2020, 9:32 pm
It looks like i have to replace my comp cams retro roller 34-432-9. The distributor drive is buggered up. Anyway i found the cam very noisy, i even removed my aluminum valve cover because of the valve train noise, they echoed. Since im replacing it, any suggestions on what cam i should look at that will still work with my lifters and pushrods. It a 501 scat stroker with srp dished pistons with about 9.7-1 comp. ported dove heads, headers, performer rpm air gap and a sniper efi.
sledhead1
Hydraulic roller cam Empty Re: Hydraulic roller cam
Post  rmcomprandy March 16th 2020, 10:17 am
sledhead1 wrote:It looks like i have to replace my comp cams retro roller 34-432-9.  The distributor drive is buggered up.  Anyway i found the cam very noisy, i even removed my aluminum valve cover because of the valve train noise, they echoed.  Since im replacing it, any suggestions on what cam i should look at that will still work with my lifters and pushrods.  It a 501 scat stroker with srp dished pistons with about 9.7-1 comp. ported dove heads, headers, performer rpm air gap and a sniper efi.
Use a solid roller lifter & cam or a good flat tappet grind.
Post  sledhead1 March 16th 2020, 6:51 pm
I am wanting to keep cost down and reuse my lifters, springs and hopefully pushrods. Im leaning toward a voodoo hyd roller and see if it quieter. Not sure if a crane or howard would be any different? Live and learn, i should have went solid roller but compcams talked me into the hyd.
sledhead1
Post  rmcomprandy March 17th 2020, 6:50 pm
sledhead1 wrote:I am wanting to keep cost down and reuse my lifters, springs and hopefully pushrods.  Im leaning toward a voodoo hyd roller and see if it quieter.  Not sure if a crane or howard would be any different?  Live and learn, i should have went solid roller but compcams talked me into the hyd.
OH ... they are Comp Cams hydraulic roller lifters.
Now I understand your plight; good luck, the noise problem is probably not the camshaft.
Post  sledhead1 March 19th 2020, 1:00 pm
Are you saying its the lifters that are crap?
sledhead1
Post  gt350hr March 19th 2020, 2:05 pm
Sure sounds like the voice of experience to me.
gt350hr
Post  sledhead1 March 19th 2020, 2:41 pm
So are they defective or are they useable just noisy
sledhead1
Post  rmcomprandy March 19th 2020, 11:54 pm
sledhead1 wrote:So are they defective or are they useable just noisy
The ones I have tried to use are usually noisy like a regular " high rate leak down lifter" is, when running.
Post  sledhead1 March 20th 2020, 1:31 am
Well i guess i bought the marketing. They calm lowest leakdown rate but i guess compared to what. Well ill try this voodoo cam, hoping pushrods will still work and see what happens this weekend. So much money for a set up i was hoping would be more reliable with todays oils.
LINK BAR RETRO-FIT HYDRAULIC ROLLER LIFTERS (Patent Pending)
Precise piston fit for lowest leakdown rate
Patent-pending piston allows trapped air to escape lifter for faster “pump up”
Axles produced from premium 52100 heat-treated steel for increased wear resistance & overall strength
Lightweight body design
Includes (16) lifters
APPLICATIONS
Ford Big Block 429, 460 & FE 390-428; Retro-fit roller lifters for blocks originally equipped w/ a flat tappet cam
SPECIFICATIONS│.875” Diameter│147g Weight│2.60” Seat Height│
sledhead1
