530ci build
530ci build
Hi I am curious what aluminum heads would support 1200- 1300 hp in a 530ci truck pulling class? I currently run in a smaller pulling class with iron dove heads but am considering going up a class. Thanks for any input
Ford466- Posts : 7
Re: 530ci build
Ford466 wrote:Hi I am curious what aluminum heads would support 1200- 1300 hp in a 530ci truck pulling class? I currently run in a smaller pulling class with iron dove heads but am considering going up a class. Thanks for any input
To make that kind of horsepower with that size engine would require a high RPM level so, something short stroke with a big bore and probably a "C" head or better.
Re: 530ci build
What Randy said,,,,plus a full set of titanium valves, shaft mount rockers, dry sump, vacuum pump and etc. It takes a big budget to make that power in truck pulling. Plus you have to sustain WOT for about 15 to 18 seconds.
c.evans- BBF VENDOR SPONSOR
Re: 530ci build
c.evans wrote:What Randy said,,,,plus a full set of titanium valves, shaft mount rockers, dry sump, vacuum pump and etc. It takes a big budget to make that power in truck pulling. Plus you have to sustain WOT for about 15 to 18 seconds.
YES ... you are basically building a 1990's "Pro Stock" engine.
Re: 530ci build
Thanks for the replies, maybe I will stay in my class looking at the cost of parts it is not in my budget to go up a class just yet. How much work would it take to get my dove heads to make me 850 hp I dont know if it's possible but am just curious, I currently have a little over 750 hp.
Ford466- Posts : 7
Re: 530ci build
Ford466 wrote:Thanks for the replies, maybe I will stay in my class looking at the cost of parts it is not in my budget to go up a class just yet. How much work would it take to get my dove heads to make me 850 hp I dont know if it's possible but am just curious, I currently have a little over 750 hp.
I have seen a little above 750 with a 429 and 9,000 RPM but, not 850 HP.
Somebody will probably get there some day. The issue is that not many people have tried with a D0VE head.
Re: 530ci build
Randy ,
What is the potential of the Eliminator iron head or the super rare Blue Thunder iron head made in the past I have only heard about but never seen?
gt350hr- Posts : 662
Re: 530ci build
gt350hr wrote:Randy ,
I have no personal experience with the Eliminator head but, the Blue Thunder and even the Iron Cobra Jet can get there.
» 530ci build
» E4OD build reccomendations for a 79 f150... first transmission build, no ideah what I'm doing
» No rules BBF nitrous build - Let's build it
