FOUND 429 CJ oil pump cover only....
Anybody have a bottom cover only? Used is OK. Mine is missing. Sure I could just buy a new pump but thought someone might have a cover from a pump with a broken flange. PM if you can help this cheap aZZ.
gt350hr- Posts : 662
No luck!
GT I checked my oil pump pile so sorry no luck .I cant blame you for wanting a used cover 460 oil pumps are expensive ! Doug
manofmerc- BBF CONTRIBUTOR
Re: FOUND 429 CJ oil pump cover only....
Thanks manofmerc . Time is on my side and somebody may have one with a broken flange.
Thanks to Jack's Ford Parts. He had a cover from a broken pump. Life is good.
Good for you !
So glad for your stroke of good luck ! Sadly your post is about the only exciting one on here.Good luck with your oil pump young man .Doug
rbro460 likes this post
Back on the want list.
If you're still looking then I just ended up with a few extra. Lemme know
Yes Paul I need one or two bottom covers. My pump was dropped and has a broken ear on a perfectly new pump. It's a shame to throw it away when a cover replacement would fix it. Maybe next time you are down at Van's we can get together or PM me and we can do the pay/ship thing.
Gregaust likes this post
I'll call you later this week and tell you what I've got.
Thanks Paul , MUCH appreciated.
cRandy
cRandy
I have a factory CJ pump if you need one
Thanks , I have a brand new pump from P.O.P. but it was dropped and damaged the cover , so I just need a cover. Sounds like Paul has a couple and he's local to me.
...scheduled to arrive this coming Monday via USPS
THANK YOU Paul!!! Just what I needed. Got here safe and sound and bolted on last night , covered up with the oil pan.
Paul Kane likes this post
A lot of the aftermarket versions of these pumps do not have a pathway for filling the gerotor from both sides whereas the original Ford Motor Company pump did.
A second pathway, (though much smaller than the Ford pump cover has), can usually be machined into an aftermarket CJ pump cover.
I sent over an original gerotor cover from a std volume dual-entry 429 CJ oil pumprmcomprandy wrote:A lot of the aftermarket versions of these pumps do not have a pathway for filling the gerotor from both sides whereas the original Ford Motor Company pump did.
Thanks Paul ! That cover is exactly like the damaged one I am replacing. Dual entry function ( why "I" use them) is in tact.
Again MUCH appreciated,
» What a pisser ready to fire it up and water leak
» Water pump cover tapped
» Marine Cam Driven Water Pump cover
» Timing Cover Vacuum pump fittings New $$$$
» Elec water pump and valve cover 460 BBF
