Cylinder head selection
Musky
EverySparePenny
Cylinder head selection Empty Cylinder head selection
Post  EverySparePenny July 8th 2020, 2:03 pm
Working towards a 480" ish truck pull engine, iron block aluminum headed, ruled to nothing "bigger" than an A head. Goals in mind are 2+ horse/cube heavy on the + side, peak hp somewhere in the 8000's for rpm and 9000 or just shy of operating rpm.
Do I go straight to the A head? Is the SR 71 "enough"? Is there some other head I should be looking at?
EverySparePenny
Musky likes this post
Cylinder head selection Empty Re: Cylinder head selection
Post  Musky July 13th 2020, 7:03 am
I am debating the same thing, but with more cubes. We do not have any cubic inch limit. I am planning on running a 598 or a 612 and most likely will go straight to the A-460 heads.
Musky
EverySparePenny likes this post
Post  rmcomprandy July 13th 2020, 10:32 am
EverySparePenny wrote:Working towards a 480" ish truck pull engine, iron block aluminum headed, ruled to nothing "bigger" than an A head.  Goals in mind are 2+ horse/cube heavy on the + side, peak hp somewhere in the 8000's for rpm and 9000 or just shy of operating rpm.
Personally, everything will be determined by how much money you are willing to spend on this project.
You are looking at an early 90's Pro Stock type engine but, a smaller bore ... 4.530", (instead of 4.625") x 3.700".
Post  dfree383 July 14th 2020, 11:10 am
Wave tuning is the game, can you get the intake and exhaust in tune to make power in that range?
Post  68formalGT August 14th 2020, 1:02 pm
Eliminator is working on putting out a A+ head that has revised valve angles and a rotated combustion chamber.
Post  rmcomprandy August 14th 2020, 3:56 pm
A tunnel ram with "A" heads would be my personal choice here.
Post  c.evans September 5th 2020, 1:14 am
Go with the TFS A-460 heads,,, but not a set off the shelf. Your professional Ford custom engine builder will probably want a bare set, or even an unmachined set to install CuBe seats, have a smaller combustion chamber, a full set of titanium valves, and shaft mounted rocker arms such as W. W. Engineering
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
