what valve springs for M-6250-A514
what valve springs for M-6250-A514 Empty what valve springs for M-6250-A514
Post  hbstang July 23rd 2020, 11:33 pm
solid roller cam?what installed height and spring pressure?or can you recomend a spring/brand part number?this is on A429 heads in a 545.
what valve springs for M-6250-A514 Empty Re: what valve springs for M-6250-A514
Post  rmcomprandy July 23rd 2020, 11:56 pm
hbstang wrote:solid roller cam?what installed height and spring pressure?or can you recomend a spring/brand part number?this is on A429 heads in a 545.
This will depend upon exactly when the engine was originally built as I am aware they used 3 different valve springs on that roller cammed engine.
The PAC-1243 is the best of all of them.
Post  dfree383 July 24th 2020, 2:46 pm
Comp cams 954-16 for a street build and under 6500 rpm
