Need help with valve springs
deliveredfast
lx545
Need help with valve springs Empty Need help with valve springs
Post  lx545 August 19th 2009, 10:54 pm
i have a comp 312h hydraulic flat tappet and it recommends the comp 928 springs, my problem is they are 160#@1.8 something, well my installed height is 2.050 which i cannot find a spring with the like specs any help would be appreciated thanks-JJ
lx545
Need help with valve springs Empty Re: Need help with valve springs
Post  deliveredfast August 19th 2009, 11:12 pm
You may have to shim the springs to get the 1.8 installed height.
deliveredfast
deliveredfast
Post  c.evans August 19th 2009, 11:23 pm
That would be a whole lot of shims, .250" worth. I'd suggest that you do some research on the Comp Cam site and see if there is a taller spring that is still a mild spring. Then if not, what about a set of shorter valves, or I'd say use minus .050" locks and then the shims, or big washers in your case! Very Happy
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bbf-falcon August 19th 2009, 11:32 pm
Are you also using spring cups?
Post  lx545 August 19th 2009, 11:39 pm
yes i'm using spring cups ive looked on comps site nothing really that tall thats mild enough if i stretch out the shorter springs they are under the reccomended seat pressure
lx545
Post  IDT-572 August 20th 2009, 12:03 am
Be careful going with a tall spring and short lift, you will lose needed over the nose pressure.
A 927 comp spring would probably work, but you would need to break it in with the inner out, because the open pressure would be a little high. Install it at 2.025 @160# and at .600 lift 1.425 @close to 450lb. Spring rate is 498 per inch.
Just something to look at. Could be some more.
Post  dfree383 August 20th 2009, 2:26 pm
What heads and parts are you running that you managed to get over 2"?
Post  lx545 August 20th 2009, 4:50 pm
procomp heads manley spring cups doug herbert 10 deg retainers and pep 2.19 1.76 stainless valves, those comp 927 look pretty good imo
lx545
Post  DanH August 20th 2009, 6:16 pm
i got a set that can be made to work. sent you a PM
DanH
Post  lx545 August 20th 2009, 8:09 pm
pm sent and im getting my heads flowed tomorrow so i can get a better idea of what cam i might need thanks for your help guys-
jj
lx545
Post  bruno August 20th 2009, 8:29 pm
hey JJ if you dont mind can you post your results ...that would be sweet Very Happy
http://WWW.CKRME.COM
Post  lx545 August 20th 2009, 8:46 pm
i will definetly post results hopefully i wont be to ashamed of my results first set of heads of really ported with the help of you experts, its been 6.60's @120 in the 1/8th with 545ci pump gas motor with some problems so maybe they'll do ok for a amatuer, thanks bruno
lx545
Post  rmcomprandy August 20th 2009, 8:58 pm
The ProComp head and your valve combination is the reason. Those heads use D3VE length valves which are shorter than D0VE's or CJ's.
A NASCAR counterwound double spring from P.S.I. is the only ones to go in that tall and have the pressures you want - that spring is expensive though.
The closest CompCams which will work for you is the #935
Personally, I can't imagine ANY hydraulic which calls for a spring with 160 pounds on the seat.
Post  lx545 August 20th 2009, 9:15 pm
i thought it was kinda wierd myself and also that cam is kinda noisy ive heard its the grind, sounds almost like a solid but looked beautiful when i took it out so i dunno what the noise was about none of my rollers were noisy so anyway.
lx545
Post  rmcomprandy August 20th 2009, 9:19 pm
lx545 wrote:i have a comp 312h hydraulic flat tappet and it recommends the comp 928 springs, my problem is they are 160#@1.8 something, well my installed height is 2.050 which i cannot find a spring with the like specs any help would be appreciated thanks-JJ
What Rollers ... ?
Your post says FLAT TAPPET.
Post  lx545 August 20th 2009, 9:28 pm
sorry ive had two roller cams in the motor
lx545
