Valve Springs
Valve Springs Empty Valve Springs
Post  geno September 19th 2013, 1:29 am
If you move down in cam size, do you have to go down with the springs also? I have an 801 lift and want to install a 765. Would the springs be too much for the new cam?
Thanks,
Geno
geno
geno
Valve Springs Empty Re: Valve Springs
Post  dfree383 September 19th 2013, 2:16 am
What springs and installed height are you running now?
Most of the time it won't be a big deal, but there are exceptions.
Post  geno September 19th 2013, 11:32 am
The springs that were installed were Comp Cams 944-16. Seat load: 190 lbs @ 1.950 - open 747 lbs. @ 1.200' - spring rate : 743 inch lbs. - coil bind is 1.100. Hope this helps.
Thanks again
Geno
geno
geno
Post  dfree383 September 19th 2013, 11:50 am
Those are good springs. if you installed them at 1.950 you are still pretty good shape, the .800 - lash put you at about .075 from coil bind the .765 cam is still relatively tight to that at .115, not ideal but it should work fine. you could slide a little bit of shim under the springs to get it a bit tighter.
Post  geno September 19th 2013, 1:53 pm
Thank you dtree. I'll slip a shim in before I install the heads. Once again, Thanks
Geno
geno
geno
Post  IDT-572 September 19th 2013, 4:01 pm
Over the nose pressure is just as important as your seat pressure..............
