Valve springs
powerstrokeace
Valve springs
Guy's what's been your choice of valve spring as of lately. I have a 555 with Motorsports A460 heads and we have been checking this over and found 2 inner springs broken. There K-Motion 1000H's and did a search and the comments left me feeling 50/50 about buying the same for replacements. These came with the motor when we bought the car. K-Motion doesn't even have a website any more. I read somewhere there"s only 2 spring manufactures in the U.S and one was Peterson spring and they make the PAC springs? Any truth to that
Ace
Ace
powerstrokeace- Posts : 1496
Re: Valve springs
I've used both PAC and Manley in the past with good results.
schmitty- Posts : 4538
Re: Valve springs
The springs that come on the new Trick Flow A460's are some good ones. Trick Flow rebrands them with a TFS part # but as far as I know they are Manley Nex Tek springs. part # 221424-16
If the TFS springs are not Manley the specs are the same.
Re: Valve springs
This is the spring I have used for years (# 221424-16 Manley). I have a 2.300 stainless valve in my P-51 headed 580 and run through the 1/4 mile at 7800 with no problem.David Cole wrote:The springs that come on the new Trick Flow A460's are some good ones. Trick Flow rebrands them with a TFS part # but as far as I know they are Manley Nex Tek springs. part # 221424-16
Just remember, push rods are just as important in keeping your valve train happy.
Re: Valve springs
The springs on your tfs heads were A Erson part # . They are made by the same mfr. as the Manley......same spring in a different box.
The tfs A460 springs are now 1224 PAC.
Re: Valve springs
x2!schmitty wrote:I've used both PAC and Manley in the past with good results.
Re: Valve springs
isnt the PAC 1224 double setup about the same as the NEXTEK 221447 tripples with the inners removed ??
jc10000rpm- Posts : 193
