Valve springs?
jason
Valve springs?
Found a broken inner spring so I'm gonna change them all out . Who's springs last the longest on a solid roller?
jason- Posts : 220
Re: Valve springs?
Thats a loaded question...... Whos Roller Cam Lasts longer?
Re: Valve springs?
I know , how bought what valve springs is everyone using on their solid rollers?
jason- Posts : 220
Re: Valve springs?
whos cam and whats specs? What Springs where you running and how much time is on them?
Re: Valve springs?
Personally, I usually use the PAC stuff but, there are a bunch of other brand valve springs which will do the job IF they are not overstressed.
They ALL have a cycle life which is different depending upon what they are required to do.
Re: Valve springs?
i've had good luck with the manley green stripe from Lem.also had erson before with good service,i think they're the same spring as manley.i have pac on the new heads so time will tell.....
Re: Valve springs?
. I was thinking PAC but wasn't sure, I think I'll give them a try. Thanksrmcomprandy wrote:Personally, I usually use the PAC stuff but, there are a bunch of other brand valve springs which will do the job IF they are not overstressed.
jason- Posts : 220
Re: Valve springs?
MANLEY NEXTEC ...BEEN ON BOTH BUILDS OVER 400 PASSES
Re: Valve springs?
bruno wrote:MANLEY NEXTEC ...BEEN ON BOTH BUILDS OVER 400 PASSES
400 passes? damn thats like 95 years as much as you race............
Re: Valve springs?
richter69 wrote:bruno wrote:MANLEY NEXTEC ...BEEN ON BOTH BUILDS OVER 400 PASSES
LMAO .... the 521 had 150 before i got the deal
Re: Valve springs?
you mean it had 375 before you got the deal lol.
Re: Valve springs?
I run Manley polished next ekes, and agree with Bruno, they seem to last a good while if you back them off during the off season.
