Eliminator ultra block prep
Eliminator ultra block prep Empty Eliminator ultra block prep
Post  2 wicked January 16th 2021, 11:47 am
We have a new ultra block, besides deburring the block, checking oil galleys were drilled completely, beveling drain backs and all sharp edges, drilling oil pump port to 9/16", and a oil bleed on front cam journal for timing gear thrust plate lubrication. Is there any other mods that need to be addressed? I have seen some recommendations to bore the main oil galleys to 1/2" like the a460 blocks. Is this necessary? 4.5 stroke 7200/7400 rpm. Thanks cory
2 wicked
Eliminator ultra block prep Empty Re: Eliminator ultra block prep
Post  BOSS 429 January 17th 2021, 4:16 am
2 wicked wrote:We have a new ultra block, besides deburring the block, checking oil galleys were drilled completely, beveling drain backs and all sharp edges, drilling oil pump port to 9/16", and a oil bleed on front cam journal for timing gear thrust plate lubrication. Is there any other mods that need to be addressed? I have seen some recommendations to bore the main oil galleys to 1/2" like the a460 blocks. Is this necessary? 4.5 stroke 7200/7400 rpm. Thanks cory
a lot of that is silly
QtrWarrior likes this post
Post  dfree383 January 17th 2021, 9:30 am
Why are you redrilling oil galleys?
Post  2 wicked January 17th 2021, 10:25 am
Sorry for the mis understanding. I have read a few articles that recommend drilling priority main galley to 1/2" from 3/8" as far as checking a brand new block for proper machining, deburring casting flash, and beveling all sharp edges. The cam thrust plate piling mod is recommended by eliminator. When using roller cam bearing. At least in my paperwork. Thanks cory
2 wicked
