Induction Solutions Boogie Box
Making horsepower is easy… but managing and effectively applying horsepower is the real key to winning races.
This is where the Boogie Box comes in! When it comes to getting your car down the track as quickly as you can, resolution and consistency are key. The Boogie Box will give you outstanding control regardless of the tire or racing surface you’re on.
The Boogie Box can progress a single wet stage of nitrous with the nitrous and fuel being controlled individually, or progress two wet stages with the nitrous and fuel being linked. Each output has individually configurable ramps and hertz settings. Our controller can take multiple parameters into consideration in order to activate or deactivate the nitrous systems (e.g. RPM windows, fuel or nitrous percent, clutch input, and time).
Boogie Box NPC-1006 Progressive Nitrous Controller Features:
NO laptop required to program
Progress a single stage with separate nitrous and fuel ramps for max control
Progress two stages with matched nitrous and fuel control
Each Solenoid output has adjustable hertz from 10-30 Htz
The Boogie Box will hold/save 3 separate set up files
Each set up file can have from 1 to 5 ramps in each for maximum control
The trans brake/ clutch interrupt is built into our box to help simplify wiring
Trans brake/clutch input activation delay timer. This function can be used to ignore the input while making a shift after the launch for manual transmission applications
Integrated +12 volt outputs for each stage that can be used for timing retard activation. The timer outputs can also be configured to operate based on controller inputs, time, engine rpm, nitrous percentage, and fuel percentage.
RPM input as well as RPM window switches
Activation input is 8-16 volts
TPS activation function if needed
Hold and wait option
Billet anodized enclosure
Stainless Steel back plate to help guard against RF interference
Bright white LCD with black graphic screen for easy to read set up
High quality Delphi connectors with harness
Easy to program touch switch programming
The box is fully potted with epoxy for vibration and moisture protection
Box measures 4.5” X 3.5” X 1”
GTmustang and 68formalGT like this post
» for INDUCTION-SOLUTIONS
» Thank you Induction-Solutions
» Thanks Induction Solutions
» Induction Solutions
» intake off to INDUCTION-SOLUTIONS
