convert to full float connecting rod
has anyone on here converted stock rods to full float? use what part number bronze bushing and where to acquire reamer from? have a nice day.
Kobelco- Posts : 101
Re: convert to full float connecting rod
Eagle has the bushings t do it.
gt350hr- Posts : 662
Kobelco likes this post
Bronze bushing aside, I've run lots of stock rods that were honed out to float the wrist pin, no bronze bushing. It might be prudent to drill an oil hole or two through the pin boss so as to allow lubrication but I suppose this feature could be application specific. When running floated rods steel-on-steel, a thou per inch of pin diameter is a good rule of thumb (ie, for 1.040" pin hone the pin boss for ~0.0010"-0.0012").Kobelco wrote:has anyone on here converted stock rods to full float? ...
Paul Kane wrote:Bronze bushing aside, I've run lots of stock rods that were honed out to float the wrist pin, no bronze bushing. It might be prudent to drill an oil hole or two through the pin boss so as to allow lubrication but I suppose this feature could be application specific. When running floated rods steel-on-steel, a thou per inch of pin diameter is a good rule of thumb (ie, for 1.040" pin hone the pin boss for ~0.0010"-0.0012").Kobelco wrote:has anyone on here converted stock rods to full float? ...
Street use and light hot rod'ing ok steel on steel? I'd still like to do a set of rods with bronze have a reamer number? it would have to be piloted I would think.
» Valve float?
» valve float
» Quick Fuel Float Question
» Cut retainer grooves in press pistons for full float
» Holley float level clear sight plugs
» valve float
