Oil pressure problem on my 598
chappy89
Oil pressure problem on my 598 Empty Oil pressure problem on my 598
Post  chappy89 December 29th 2009, 11:38 am
Ok guys, I need some help here. Quick rundown on my combo...C&C 10.32 RD block, 4.5 LAE Crank, BME Rods, Diamond Pistons. Running a Peterson WetVac external pump, 50% driven off the crank, have a valve cover relief from Peterson (adjustable) with 2 -12 hoses to the vac pump. The engine only makes around 20psi at idle, and barely makes 30 psi when revved up. If you sustain RPM it will actually begin to drop. Have tried adjusting vacuum relief, oil pressure relief screw on the pump is all the way in. Crank clearances are good, as are bearings (just removed and checked last week). Also running Jesel dogbone lifters. I have no oil restrictors in the engine.
Any ideas would be a huge help! Need to get this figured out so we can go testing.
Chappy
chappy89
Oil pressure problem on my 598 Empty Re: Oil pressure problem on my 598
Post  Lem Evans December 29th 2009, 1:52 pm
I don't know about your C&C block but if the restrictors are omitted from the A460 iron block the oil pressure can get real funky .
Post  chappy89 December 29th 2009, 2:11 pm
Like how so? The only restrictors that I have go in the backside of the block on each lifter oil galley. Carroll at C&C recommended I install them, but Jesel said not to. So I need the advice of a Ford engine builder, much like yourself Lem (I understand you are one of the best!). It won't be too much trouble to put them back in. Pull tranny, flexplate, etc. I just need to know this will fix my problem. Can I call you and take up some of your time?
Thanks again
Chappy
chappy89
Post  Lem Evans December 29th 2009, 3:34 pm
you have a pm.
Post  chappy89 December 29th 2009, 3:35 pm
Thanks Lem. Gonna call shortly.
chappy89
Post  bbf-falcon December 29th 2009, 9:09 pm
Sure sounds like a huge leak somewhere Shocked
Post  Nevs December 29th 2009, 9:16 pm
bbf-falcon wrote:Sure sounds like a huge leak somewhere Shocked
X2. I'm sure we ran the restrictors in our RDI block.
Post  chappy89 December 30th 2009, 9:56 am
Thanks guys. Talked to Lem. We both think that the restrictors are causing the problem. Will put them in this weekend and retest. Let everyone know what I find.
Chappy
chappy89
Post  Doug Rahn December 31st 2009, 7:22 am
Chappy, I know this isn't causing your problem but just a recommendation from my experience. I have the same oil pump setup and regulator on my 598 except it's the A460 block. Pressure is set at 65-70 psi and I have the vacuum set at 7-8 inches. Anything above 10-12 inches of vacuum and the oil pressure starts to fluctuate a lot. The pump starts to get in a tug of war with its self. Wink
Post  BOSS 429 January 3rd 2010, 1:36 am
I have no oil restrictors in the engine.< this is the problem.
they have to be there,
Post  chappy89 January 6th 2010, 3:34 pm
BOSS 429 wrote:I have no oil restrictors in the engine.< this is the problem.
Trust me, they weren't there. I had them in a bag my machinist gave me. But they're in there now.
I now have around 80-90 psi when the engine fires up. Crazy how a those restrictors make such a huge difference.
Thanks to Lem and Carrol Carter for all their help. I think my oil problems are solved. Now as soon as the fuel pump cable comes back, this thing is going to the track!
Chappy
chappy89
Post  bbf-falcon January 6th 2010, 6:44 pm
I love it when a plan comes together Smile Good Luck man Cool
Post  Lem Evans January 6th 2010, 7:31 pm
Cool
