Raised cam
Raised cam  Empty Raised cam
Post  djfry460 May 25th 2022, 8:04 am
Good morning all,
I'm new to this board but not to engines in general. Had several BBF's over the years but nothing more than 500 HP.
Curious about when the build requires a raised cam block? Is it HP dependent or RPM based?
It would make sense for shorter pushrods and improved stability but i don't know where that "line" is....
thanks for any response to this.
Have a good day.
djfry460
Raised cam  Empty Re: Raised cam
Post  dfree383 May 25th 2022, 10:02 am
When you run out of crank to cam clearance.
Post  wickettoby1 May 25th 2022, 12:33 pm
djfry460 wrote:Good morning all,
Have a good day.
That’s a Chevy problem with their measly 9.8” deck heights 😂
wickettoby1
QtrWarrior and Mark Miller like this post
Post  djfry460 May 26th 2022, 7:56 am
Sorry all, i meant at what performance level is it required and / or best practice?
i understand the physical limitations
djfry460
Post  rmcomprandy May 26th 2022, 10:19 am
djfry460 wrote:Sorry all, i meant at what performance level is it required and / or best practice?
"Physical Limitations" is the only reason it would be REQUIRED.
QtrWarrior likes this post
Post  djfry460 May 26th 2022, 10:20 am
ok thank you
djfry460
Post  wickettoby1 May 26th 2022, 8:54 pm
You can’t swing a big stick in a small yard 😂
wickettoby1
djfry460 likes this post
Post  Paul Kane May 27th 2022, 2:00 pm
Have a good day.
This is a BBC problem.  Next to the BBC, the 385 Series is already "rasied cam" block as a matter of speaking.  There are no camshaft clearance issues with any of the common BBF stroker kits, not even with alumnum rods.
Post  Paul Kane May 27th 2022, 2:10 pm
Deck height has nothing to do with it. In fact, aftermarket 385 Series blocks were once available in a shorter 9.75" (and even 9.30") deck height.
It's specifically the cam-to-crank centerline dimension of the BBC that is sometimes the issue.  The Ford 385 cam-to-crank centerline is 6.078" while the original BBC cam-to-crank centerline is just 5.152" (5.552" on the raised cam BBC cylinder blocks).
Post  djfry460 May 31st 2022, 7:34 am
Thank you all for the information.
djfry460
