Holley 3310, Holley Snipper or FiTech ?
lathechips
Holley 3310, Holley Snipper or FiTech ? Empty Holley 3310, Holley Snipper or FiTech ?
Post  lathechips August 30th 2022, 9:58 pm
74 Thunderbird 460, Edelbrock Performer, duraspark, advanced cam timing set , in a 56 F100. What carb or efi ? + anything else you would like to add.
lathechips
Holley 3310, Holley Snipper or FiTech ? Empty Re: Holley 3310, Holley Snipper or FiTech ?
Post  Mark Miller August 30th 2022, 11:29 pm
lathechips wrote:74 Thunderbird 460, Edelbrock Performer, duraspark, advanced cam timing set , in a 56 F100.  What carb  or efi ?  + anything else you would like to add.
Holley 3310 much cheaper and easier to install!!FI Tech and Holley Sniper harder to install[more involved]easier to tune if you don't know about carbs or want to work on them!!
Post  BBFTorino August 31st 2022, 4:11 pm
How much money ya got?? Very Happy
Post  dfree383 September 5th 2022, 2:01 pm
Carbs are cheap and easy.
The low end EFI kits are hit and miss in my experience
As long as you know how to tune a carb their is no hp advantage in the EFI
Post  rollercam1 September 11th 2022, 5:51 pm
I just finished converting from a prosystems 1000cfm carb to the 4500 sniper. I have to say going out and bumping the starter, having it fire up and idle cleanly at 925rpm's regardless of sitting for 2 weeks or 2 minutes is fantastic. There are plenty of videos/people out there to help with tuning. All TBI type EFI's will not like dual plane intake manifolds. The holley can work with duraspark right up front and even give you timing control if you chose. a little more involved up front with EFI, but the only way to go. It simply gives you far more information and control over your setup. You can have traction control with a simple front wheel speed and driveshaft RPM sensor, you can see converter efficencies, timing control down to 1 degree per 100 RPM's. A carb will not do those. If you spend your life at idle or WOT, a carb will do anything EFI will do.
rollercam1
rollercam1
Post  rmcomprandy September 11th 2022, 6:59 pm
That IS about the jist of it ...
EFI will be hard-pressed to match the power of a similar size carb however, it will do almost everything else better if tuned correctly.
