69 429 heads swap on 86 460
69 429 heads swap on 86 460 Empty 69 429 heads swap on 86 460
Post  pat54632 October 31st 2022, 2:34 pm
So I have an 86 F350 with a stock 460. The exhaust bolts are all rounded off and rotted and can not be removed. I have a set of fresh C9VE heads off a 69 429 thunderjet that I just had the exhaust ported and valve guides replaced. Already had hardened valve seats installed. My plan is to just use the stock rocker arms and pushrods off the 69 429 that would have gone along with these heads. Are there any issues with using these stock valve train parts with the cam in the 86 460? I also plan to change the timing chain to straight up. Thanks.
pat54632
69 429 heads swap on 86 460 Empty Re: 69 429 heads swap on 86 460
Post  rmcomprandy October 31st 2022, 11:52 pm
pat54632 wrote:So I have an 86 F350 with a stock 460. The exhaust bolts are all rounded off and rotted and can not be removed. I have a set of fresh C9VE heads off a 69 429 thunderjet that I just had the exhaust ported and valve guides replaced. Already had hardened valve seats installed. My plan is to just use the stock rocker arms and pushrods off the 69 429 that would have gone along with these heads. Are there any issues with using these stock valve train parts with the cam in the 86 460? I also plan to change the timing chain to straight up. Thanks.
THAT will all work together just fine ...
Post  dfree383 November 1st 2022, 6:49 am
X2 it will give you a nice boost in compression too.
Post  pat54632 November 1st 2022, 8:12 am
Perfect that’s the goal. With these roughly 75cc heads and a .040” head gasket any thoughts on what the cr will be? Wondering if I can still run 87 or if I’ll have to go to higher octane.
pat54632
Post  supervel45 November 1st 2022, 5:36 pm
23cc .030" in the hole 75cc comes to 9.14/1 if that's what you have for your setup. On the gas maybe/probably OK on the 87.
Double check your lifter preload just because.
