BOSS 429 HEAD NEW REPLACEMENTS OHIO SWAP
I will be bringing NEW BOSS 429 heads with me for show and TELL, these can be bought a couple of diff ways,
OEM style with cooper ring grooves, and O'ring grooves
with factory oiling holes in place
factory rocker pad
This head will bolt on any block
OR
set up for JESEL ROCKERS
no oil holes drilled/machined
without O'ring grooves
std for a NORMAL HEAD GASKET
I will also have the new valve covers
Along with my replacement head gasket sets
I also now sell the correct restrictors for the BOSS 429 engine
We can also change your heads over to Jesel rockers
See you at the swap
-R
factory rocker pad
OR
See you at the swap
-R
BOSS 429- Posts : 2371
Curt and Mark Miller like this post
what?
without pictures it aint happening! lol
for those of us who dont go to the meets !
hbstang- Posts : 365
paulie9fingers likes this post
Re: BOSS 429 HEAD NEW REPLACEMENTS OHIO SWAP
I was looking at the UFO website for dates. I couldn’t find anything. I thought they quit doing the fall meet?
stanger68- Posts : 500
You know we are interested, Please post images.
BOSS 429 wrote:I will be bringing NEW BOSS 429 heads with me for show and TELL, these can be bought a couple of diff ways,
factory rocker pad
OR
See you at the swap
-R
jalessi- Posts : 5
KATIE460- Posts : 6
hbstang likes this post
KATIE460- Posts : 6
KATIE460- Posts : 6
Sorry about all the period post I can’t delete them for some reason
KATIE460- Posts : 6
BOSS 429 HEAD
1, pic is of a stock BOSS 429 head with a few diff rockers, Which some of you may have seen?
top to bottom...Mine, Millers, and Allen Roots
2, Top is the TM head which I now offer with the Jesel bolt pattern already in the head
This head can come, either way, stock OEM bolt pattern, or Jesel ready!
The latter will not be gun drilled for oiling, It will oil thru the push rods as normal 429
With that said you can order the head for stock oiling, WITH O'RING GROOVES, AND WITH OR WITHOUT COOPER RING GROOVES
for NASCAR block or street block.
3, This just shows the new head with the Jesel placement compared to the OEM rocker, and where the oil hole would be if using OEM rockers
4, With the Jesel rockers, installed
5, Very early A441 head that came with OEM oiling, and pattern, switched over to Jesel, these early heads use stock rockers, later on, AR omitted the oiling, and the gun drilling and the pads were widened to accept the Jesel rockers
6, A441 standing next to a TM head, You can see the diff in the rocker pads .
7, The early A441 has to have material added to except the Jesel
8, This is just a better pic of the AR rocker on a stock Boss 429 head
Please feel free to call with questions
-Rich
There is an added charge for cutting the grooves in the deck
There is no added charge for the Jesel ready head
We can and still do the Jesel switch over on the stock oem heads or AR heads
-Rich
stanger68 wrote:I was looking at the UFO website for dates. I couldn’t find anything. I thought they quit doing the fall meet?
You thought wrong ... dates are ALWAYS the weekend after Thanksgiving.
» Spring swap at columbus is coming
» CR drop via head swap
» Boss head ?
» Spring Super Swap Columbus Ohio
» Boss head ?
