CR drop via head swap
+6
strokedmyford
kim
7LBRONCO
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
I am currently running a stock 70 429 TJet in my Bronco. It runs hotter than I like, even with the largest OE radiator. I run 91 octane, with octane booster and lead substitute. I would like to get this motor to run on "beer" (87 oct), instead of cocktails. Normal operating elevation is 7-8K'. How much compression drop would a set of uncut D3 heads give me versus the D0VE heads? Not having to add lead substitute to each tank is also a plus.
I know the 429 is OE, cause I got it from the original owner with 49K miles on it.
7LBRONCO- Posts : 26
Re: CR drop via head swap
It shouldn't run too hot...as long as your tune and cooling system are right. What thermostat, fan and shroud arrangement do you have? Also, incorrect ignition timing can cause cooling problems. By the way, how hot is "hotter than I like"...and does it remain at a fairly constant temp, or does it overheat?
87 octane may be a stretch regardless of tune, tho. '70 era stuff used a bit more compression than 87 will normally support. You're probably right in wanting to lower the squeeze if you're dead set on using the cheap stuff.
maverick- BBF CONTRIBUTOR
Keep in mind that your short block is probably 10.3" deck height, and 1973 blocks where 10.32" to lower compression. The pistons on the later engine's have more dish also I believe. My 1971 429 has the dished pistons. If you have 2 valve relief flat tops 9 to 1 compression ballpark is my estimate. Anyway I think you can get by with 87 octane.
supervel45- Posts : 4493
Identification data
Ford Galaxie 500 4-door Pillared Hardtop 429 V-8 4V Cruise-O-Matic
as offered for the year 1973 until September in North America U.S.
Production/sales period of cars with this particular specs:
September 1972 - September 1973
Modelyears:
1973
Country of origin:
USA
Make:
Ford (USA)
Model:
Full-Size 8th generation
1969-1974
Submodel:
Galaxie 500 4-Door Sedan
1969-1974
Optional equipment:
EEC segmentation:
E (executive cars)
Class:
full-size / executive car
Body style:
sedan
Doors:
4
Traction:
RWD (rear-wheel drive)
Dimensions & capacities
Length:
5575 mm / 219.5 in
Width:
2019 mm / 79.5 in
Height:
1397 mm / 55 in
Wheelbase:
3073 mm / 121 in
Front track:
1628 mm / 64.1 in
Rear track:
1633 mm / 64.3 in
Ground clearance:
130 mm / 5.1 in
Turning circle btw. walls:
Turning circle btw. curbs:
Drag coefficient claimed:
Drag coefficient estimated by a-c:
0.53
Legroom:
1st row:
2nd row:
3rd row:
Shoulder room:
1st row:
2nd row:
3rd row:
Headroom:
1st row:
2nd row:
3rd row:
Hiproom:
1st row:
2nd row:
Claimed EPA passenger volume:
Calculated EPA passenger volume:
Interior length:
Interior width:
Interior height:
Trunk (cargo) capacity claimed:
Trunk (cargo) capacity SAE:
484 / / dm3
17.1 / / cu ft
Trunk (cargo) capacity VDA:
Boot length:
Boot length max.:
Boot width:
Boot width min. (between wheel arches):
Boot height:
Loading height:
Approach angle (deg):
Departure angle (deg):
Ramp angle (deg):
Weights
Curb weight (without a driver):
2018 kg / 4449 lbs
Weight distribution f/r (%):
Dry weight:
Shipping weight:
Curb weight estimated:
Gross vehicle weight rating GVWR:
Payload:
Payload estimated:
Towing weight:
unbraked:
braked:
Sales markets
Markets, where cars with this particular specifications were sold:
North America
U.S.
Related models:
Powertrain
Engine manufacturer:
Ford 385-series V-8 429
Engine type:
spark-ignition 4-stroke
Fuel type:
petrol (gasoline)
Fuel system:
carburetor
Charge system:
naturally aspirated
Valves per cylinder:
2
Valves timing:
Additional features:
Motorcraft 4-barrel
Emission control:
Emission standard:
Cylinders alignment:
V 8
Displacement:
7033 cm3 / 429.2 cui
Bore:
110.79 mm / 4.362 in
Stroke:
91.19 mm / 3.59 in
Compression ratio:
8 : 1
Power net:
150.5 kW / 205 PS / 202 hp (SAE net)
/ 4400
Torque:
434 Nm / 320 ft-lb
/ 2800
Power gross:
Torque gross:
Redline rpm:
Fuel capacity:
83 liter / 21.9 U.S. gal / 18.2 imp. gal
Drivetrain
Gearbox:
Ford C6
Transmission type:
automatic
Number of gears:
3
Gear ratios (overall):
I
2.46 (6.77)
II
1.46 (4.02)
III
1 (2.75)
IV
V
VI
VII
VIII
R
2.175
Speed range
(max speed on gears,
top gear value theor.):
(km/h/mph)
I:
96 / 60
II:
162 / 101
III:
237 / 147
IV:
V:
VI:
VII:
VIII:
1000rpm speed:
(km/h/mph)
I:
20.1 / 12.5
II:
33.9 / 21.1
III:
49.4 / 30.7
IV:
V:
VI:
VII:
VIII:
Torque converter factor:
2.05
Final drive ratio std:
2.75
optional:
3
3.25
Front brakes:
Rear brakes:
Standard tires:
H78 - 15
Check 1973 Ford Galaxie 500 4-door Pillared Hardtop 429 V-8 4V Cruise-O-Matic alternate wheel and tire sizes ...
I could not get the link to work. This spec. sheet shows the factory compression of a 1973 4294v which should have your D3 heads.
Modelyears:
1973
Country of origin:
USA
Make:
Ford (USA)
Model:
1969-1974
Submodel:
1969-1974
Optional equipment:
EEC segmentation:
E (executive cars)
Class:
Body style:
sedan
Doors:
4
Traction:
Length:
5575 mm / 219.5 in
Width:
2019 mm / 79.5 in
Height:
1397 mm / 55 in
Wheelbase:
3073 mm / 121 in
Front track:
1628 mm / 64.1 in
Rear track:
1633 mm / 64.3 in
Ground clearance:
130 mm / 5.1 in
0.53
Legroom:
1st row:
2nd row:
3rd row:
Shoulder room:
1st row:
2nd row:
3rd row:
Headroom:
1st row:
2nd row:
3rd row:
Hiproom:
1st row:
2nd row:
Interior length:
Interior width:
Interior height:
484 / / dm3
17.1 / / cu ft
Boot length:
Boot length max.:
Boot width:
Boot height:
Loading height:
Ramp angle (deg):
Weights
2018 kg / 4449 lbs
Dry weight:
Shipping weight:
Payload:
Payload estimated:
Towing weight:
unbraked:
braked:
Sales markets
North America
U.S.
Related models:
Powertrain
Engine type:
Fuel type:
petrol (gasoline)
Fuel system:
carburetor
Charge system:
naturally aspirated
2
Valves timing:
Motorcraft 4-barrel
Emission control:
Emission standard:
V 8
Displacement:
Bore:
Stroke:
91.19 mm / 3.59 in
Compression ratio:
8 : 1
Power net:
/ 4400
Torque:
434 Nm / 320 ft-lb
/ 2800
Power gross:
Torque gross:
Redline rpm:
Fuel capacity:
Drivetrain
Gearbox:
Ford C6
Transmission type:
automatic
Number of gears:
3
I
2.46 (6.77)
II
1.46 (4.02)
III
1 (2.75)
IV
V
VI
VII
VIII
R
2.175
Speed range
(km/h/mph)
I:
96 / 60
II:
162 / 101
III:
237 / 147
IV:
V:
VI:
VII:
VIII:
1000rpm speed:
(km/h/mph)
I:
20.1 / 12.5
II:
33.9 / 21.1
III:
49.4 / 30.7
IV:
V:
VI:
VII:
VIII:
2.05
2.75
optional:
3
3.25
Front brakes:
Rear brakes:
Standard tires:
H78 - 15
Running hot, too little radiator, old plugged radiator, crappy fan, and or failed fan clutch if mechanical, no thermostat or thermostat unable to open fully. 9-1 compression at that altitude, should be able to run 85 octain. (NM and El Paso TX, as well as in Mexico)
Lack of timing also causes poor burn, so instead of making HP, all you do is make heat down the cylinder.
kim- Posts : 700
I am on my third radiator, trying to get the temps to stabilize around 180-190. Right now I am using an extra super cool radiator, which is THE biggest radiator that Ford produced for 78-9 F350 trucks. 1970 T Bird clutch fan, OE radiator shroud. This radiator dropped my temps down 5-10 degrees, compared to a new Champion 3 core. Currently, operating temp is 200 + going down the highway, or in town. I attribute this to high CR and lousy fuel. When this engine was new, regular was 91 octane, and this was a premium fuel engine! I have tried timing changes from 0 to 12 before. The more I back it off, the warmer it runs. Even sitting idling, it will run 200+ on my mechanical gauge.
Is it a 4 row radiator? My Modine super duty radiator in my 1978 F150 is 4 rows and I have seem the big top tank radiators that look just like mine with 3 rows. I am wondering if the octane booster and lead additives are raising the temp?
Is the plate between the water pump and front cover there.
strokedmyford- Posts : 126
The radiator is a 3 core. Ford never put a 4 core in this series of trucks. I know this size radiator will cool a big block, so that is not the issue.
When I got this engine, it was still pushing a 70 T Bird around. Still had the OE water pump, which I had to replace about 4 years ago, due to a dripping seal, so if it had a plate then, it has one now.
The published comp ratio is 10.5 +, depending on your source, and that indicates to me something higher than 91 octane, which is all I can buy around here. Tried going to the airport for some avgas, but they won't sell it to me. Just wanted to see if some REAL gasoline would make a difference.
I used an infrared temp gun on the T stat housing, and it showed 180-190, which is cooler than the water temps in the radiator. I have tried from 160-190 degree T stats, with no difference. I still have the original 190 stat, with the Ford oval stamped on it.
Bad fan clutch would make little or no difference at highway speeds, but I have checked mine. You can hear the difference, when the engine is revved up.
A big block replacement water pump never comes with the plate like the small blocks do. Sometimes it sticks to the old water pump and doesn't get cleaned and transfered. Seen it happen more than once, you should see it in there without disassembly.
I know the plate is not on the original pump, cause I still have it sitting in a shelf. Will Look tomorrow, AFTER the temp gets above 0.
7LBRONCO wrote:I know the plate is not on the original pump, cause I still have it sitting in a shelf. Will Look tomorrow, AFTER the temp gets above 0.
If its that Cold there you don't even need a radiator.
![affraid](https://2img.net/i/fa/i/smiles/affraid.gif)
res0rli9- BBF CONTRIBUTOR
Supposed to get down to -6 tonight. Better than the -20 we usually have this time of year!!!
Do you have a fan shroud?
In your postings I didnt see mention of a fan shroud .No doubt you have a sufficent radiator .And yes a fan clutch doest do much at highway speeds but you need all the help you can get .If you dont have a fan shroud get one it makes the fan more efficent .And find yourself a heavy duty fan clutch .And if you have a big flex fan handy try that.I would rather see you try out a better fan clutch first .Even with crappy gas and somewhat high compression you should be able to cool your truck to 190 going down the highway.Most guys on this forum have engines with more power and compression than you .In cars with much smaller engine compartments with smaller radiators .And are the water pump pulleys factory original or and aftermarket underdrive .Water pump speed maters also .Good luck you will find your problem Doug
manofmerc- BBF CONTRIBUTOR
Did the later 460's go to a revese flow water pump for serpertine belt system? Could some one mistakingly grabbed the wrong part, and it was not noticed?
And by the way I went and counted the row's in my Modine radiator, and there are four (4). It was listed for a 1973-79 Ford truck. Autozone ect. does not carry them either. I had to order it from a Modine distributor.
![Question](https://2img.net/i/fa/i/smiles/icon_question.gif)
There has never been a reversed flow water pump for a 460, even the serpentine trucks the pump turned normal rotation. Unless I'm wrong!!!
jeffgfg- Posts : 338
SVO 1995 Catolog page 25 on the 460 CJ footnotes says otherwise. It says the water pump must be changed to convert to V-belts from Serpentine, on the crate engine. I would think this applies to the stockers as well. I believe most serpentine belt set-ups are reverse rotation, because of how the belt treads over the pulley. I am not saying this is the OP's problem, just something for him to double check.http://local.aaca.org/harford/07sept345.pdf As for as factory setups looks like your correct. The older SVO crate engine's used available parts, and apparantly the water pump pulley holes are different than the V pulleys.
The water pumps turn the same direction on the serpentine systems (grooved pulley not smooth), the water pumps are different but the only thing I can tell is that it uses larger bearings and has extra mounting bosses.
If you're still interested in a bit of avgas, small airports will pump it into a can or fuel jug, but they will not pump it into your car.
I edited my above statement. The 302/351w is reverse rotation, and is so stated in the footnotes of the SVO catolog. The 460 just says the waterpump must be replaced for V-belts. They do make a couple of aftermarket reverse pumps for custom belt setups though. The bolt holes for the pulley was mentioned on another thread.strokedmyford wrote:The water pumps turn the same direction on the serpentine systems (grooved pulley not smooth), the water pumps are different but the only thing I can tell is that it uses larger bearings and has extra mounting bosses.
maverick wrote:If you're still interested in a bit of avgas, small airports will pump it into a can or fuel jug, but they will not pump it into your car.
I tried our small airport. No Sale, even in a gas can.
If I did have a reverse flow water pump, I believe the temp issue would be more severe. When I replaced the OE pump, operating temps stayed the same.
I really appreciate everyone's input. This spring I am going to swap my D0VE heads for a good pair of D3s that I have. Just need to upgrade the springs to handle a .500 lift cam.
Just curious, is the Large web D0VE block worth more than a standard web block. I know my block is the large web, from changing to a rear sump pan and oil pump.
[quote="7LBRONCO"]
Not even for the old Luscombe you've been restoring in your garage?
As for as your thick web D0VE block, it would be worth more to me if I was block shopping. Not as much as a 4 bolt SCJ block, but more none the less. As far as the reverse flow water pump, not very likely, as it does look like they are speciality after market deals, for true single serpentine belt conversions. I take it that you are running hot in winter contitions, which seemed odd. If it was Texas 100 degree heat the 200 would not be out of the ordinary, but you said Colardo and I assume winter temps? I still suspect the additives may have something to do with your heating problem. I hope you get it sorted out.
what sort of carb you have on it? a long long time ago i had a 70 model 460 i had trouble cooling.i did evrything to help it,even a custom built 4 core radiator.it would idle and not overheat but would get 210-220* down the road.i bought a new 850 dp for it and fixed my cooling problems.i always knew the 600 was too small but couldn't stand to buy more gas for it at the time.7LBRONCO wrote:I am currently running a stock 70 429 TJet in my Bronco. It runs hotter than I like, even with the largest OE radiator. I run 91 octane, with octane booster and lead substitute. I would like to get this motor to run on "beer" (87 oct), instead of cocktails. Normal operating elevation is 7-8K'. How much compression drop would a set of uncut D3 heads give me versus the D0VE heads? Not having to add lead substitute to each tank is also a plus.
I am running a 670 TA Holley carb, with 1" phenolic spacer on the stock iron intake. At this altitude, it is actually running a little rich.
Page 1 of 2 • 1, 2
» BOSS 429 HEAD NEW REPLACEMENTS OHIO SWAP
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» P-51 Head's /Head Studs/pushrods (SOLD)
Page 1 of 2
