Ons a stroker with 2.2-2.4 oil clearance and 3 on main will a stock volume pump with a HV spring work ok?
I got pretty good on guessing on a 351w the pump i needed., Since street car want maximum life with bronze gear, got oil mod done to block. Last time 1o yrs ago had to add extra quart to pan to have a chance cruising at 3000 rpms, might be that I leveled motor and doesn run as easy to rear drains. I trying for like 30/40 at lower rpms to save wear and 70 at higher RPMS with HV spring saved. Might restrict pushrods a bit, but not too much want oil to cool springs, only last effort if pan empties to fast. got Canton Foxbody pan , older type with 7 quart and canton windage screen type . Worked good on 4,14 crank, hope its fine on 4.3 stroke. Going to close of opposite side of pump area in pan so doesnt hold as much oil. Set engine at about 2 degree up hill should help also, like to run 10/30 or 15/40 to save some load on gear. Doing this on 351ws pressure would jump to max as fast as you hit the gas, loose converter will help that lol.Weekend cruise and some grocery getting when main car is down lol. Ran 92 octane with 12 to one with 180 psi and it loved it, ran high 5s with now signs of detinating =. no cap walk/fretting, got mildon caps help, going to keep eye on main webs justin case, ran motor 7500 to 8000 do to wheel stands and afraidto shit in air oe coming down hard. 1.25 60 ft. Back to pump, with playing with oil thickness does this seem doable on a 460 and there pump? think i, going to due last oil system mod and enlarge main passage from bump to block 9/16? might slightly open pump up some if it looks like it could use it and check clearance, new dont mean good. I also going to lengthen rear oil dam/plate to help keep it low on leave. also going to brace pump and its a rear sump which help brace pump some, using main studs too. Does this sound doable on a 460 oiling and its standard pump. Like to take to track once a yr, andt est and tune to get some time slips. Mostly want to go to car stuff and be around other Hotrodders. Have pay a friend to put engine in for me, because of disease in neck, mighth have to go to power steering to drive . All well have to have a Goal or Ill die in bed.
ED468- Posts : 200
Re: Ons a stroker with 2.2-2.4 oil clearance and 3 on main will a stock volume pump with a HV spring work ok?
You should have Justin Case do all the oil mods!
BBFTorino- Posts : 999
Your clearance is on the tight side but even if it was 3 thousandths a standard volume pump should be fine. Considering the tighter clearances you should probably use thinner oil than 20w-50. 10w-40 or a blend with 10w-30 would be more appropriate.
Dave De- Posts : 797
» oil pump High volume or stock
» Does a high volume oil pump necessitate a high volume oilpan?
» High Volume BBF Oil Pump - Bad Idea???
» help w/ 545 stroker and engine components , 9.5:1 pump gas, 600hp N/A
» stroker motors and stock flywheel
