oil pump High volume or stock
oil pump High volume or stock Empty oil pump High volume or stock
Post  slurm September 17th 2011, 11:45 am
Hello I am building a 466 cj heads polished stock rods and crank, hyper pistons, and plan to have about 550hp.And will be spinning it 7000rpm. My question is do i need a HV pump or can i use a stock one? I have done the oiling tricks to the block as per this forum and others but have not found anything on pumps. I am new to the forum thing and this one seems to be the most responsive. Any help is greatly appreciated.
slurm
slurm
oil pump High volume or stock Empty Re: oil pump High volume or stock
Post  69F100 September 17th 2011, 12:36 pm
What this engine going to be used for
Post  rmcomprandy September 17th 2011, 1:36 pm
I use a stock volume pump with a high pressure bypass spring.
The Kaase pump is like this but, much better metal and strength than an OEM replacement pump.
Post  cooter September 17th 2011, 1:39 pm
i use the jon kaase pump
cooter
Post  slurm September 17th 2011, 2:44 pm
I am sticking this engine in to a 72 f150 2 wheel drive with a c6 and 3200 stall. I have been getting pulled over by the local police so much with my 67 mustang with a 460 and tunnel ram that i need something of a sleeper to beat up on those little ricers. And not have a 1600 dollar worth of fines at the end of the summer for exhaust and obstruction of view because of my scoop. Twisted Evil
slurm
slurm
