magneto\distributor gear roll pin size or better quality
magneto\distributor gear roll pin size or better quality Empty magnetodistributor gear roll pin size or better quality
Post  Kobelco February 2nd 2023, 5:02 pm
I am running a msd20 the distributor gear roll pin is getting work hardened where the shaft meets the gear, ready to break more than likely. Is there a good quality pin available? Or drill oversize to ??
It drives the oil pump also.
Kobelco
magneto\distributor gear roll pin size or better quality Empty Re: magneto\distributor gear roll pin size or better quality
Post  the tree man February 3rd 2023, 1:29 am
That should be a spiral pin,tougher than a roll pin. I would just replace it with a new spiral if you have concerns about the current one.
the tree man
the tree man
Kobelco likes this post
Post  supervel45 February 3rd 2023, 3:43 pm
You may want to take a look at what Paul Kane said in post #3 while you have it apart.
https://www.460ford.com/threads/sheared-distributor-gear-roll-pin-again.116327/
It looks like some of the spec.'s in the old 460 Ford link got lost. Below is a Ford Data Sheet, that may help.
https://performanceparts.ford.com/download/pdfs/DistributorGearInstallation.pdf
