429 cj intake gaskets without exhaust cross over
429 cj intake gaskets without exhaust cross over Empty 429 cj intake gaskets without exhaust cross over
Post  70CobraDragpak March 9th 2023, 1:56 pm
So I have a 71 429cj with the Rochester carb on it and my choke doesn't work because there is no exhaust cross over to heat the choke stove spring. SOoo...I put an adapter plate and 870cfm Holley with electric choke on it yesterday. Are the gaskets w crossover available? I searched for awhile and gave up trying to find some. Alternatively I wonder how hard it would be to find an electric choke for the Rochester.... Also, my engine is basically stock w perhaps a slightly larger cam than stock. Is that 870 vac secondary going to be ok or will I need to modify something?
70CobraDragpak
429 cj intake gaskets without exhaust cross over Empty Re: 429 cj intake gaskets without exhaust cross over
Post  supervel45 March 9th 2023, 4:13 pm
https://www.ebay.com/itm/275051675223?hash=item400a5b7e57:g:eK4AAOSwk8dhqsnU&amdata=enc%3AAQAHAAAA0IoHGhoqPaumsdYY6CQ2gnj46I72z5GwCpXTm%2BtL%2FkbnKxFjjOxCC30xCr0a%2F92upU7nzN7cPD4OmkILwS5g68h6SLzcDAaWy7Sn3NX51Y2UIu1H7hoiKSn1B%2FpeLJRAIfj6hj2awI7XrlloiOhvEVFA3BLfCGkhfgd7xi3ln7gmL8vrirSP4DfBBMQOPlpfxHABm8%2B2zKBcI86zGT7CqMe365WqNJ2ugBMcNq%2BNGsW%2Bn41MiT7vXm1BizUnOiqyer6nR8QfFsU4hxmzQF6hGuE%3D%7Ctkp%3ABk9SR-iG1P7YYQ
Here is a the marine gasket, below, they usually came with SCJ intakes, and std. port heads, also the Kohler generator 460's are the same. The one (Kohler) I worked on had the metal tabs but, no holes in them like the marine gasket. It had an SCJ intake with std. passenger car heads with no casting numbers and gaskets matched the intake. They were the black Print-To-Seal.
https://www.ebay.com/itm/234652143322
^Victor Reinz/Fel-Pro 17368 part number
You can try and double check the part number or get someone to measure the port of one, they look like CJ's to me though. A marine shop could check, or Lem here knows being the Boat Guy.
I don't think you can convert a Divorced Choke Q-Jet to electric? They make electric conversion kits for the Hot-Air Q-Jets but, that's not what came on a 429CJ.
Put a SCJ intake on it if you want the most out of a square flange Holley. Get a late model one off a Boat for much less then a original SCJ date coded one. A Holley 750 Double Pumper would be my suggesting, if you are not racing it and want better mileage and low end response.
PS: You can go manual choke on your Quadrajet.
https://quadrajetpower.com/manual-choke-conversion-cable/
Last edited by supervel45 on March 9th 2023, 8:53 pm; edited 1 time in total (Reason for editing : Correct Fel-Pro part number)
Post  Paul Kane March 9th 2023, 7:59 pm
As an aside, should you opt to go with the non-OEM carb and wish to omit the OEM choke stove then we just finished a run of Choke Stove Block-Off Plates.  I haven't actually announced these yet but since we're on the subject I might as well let the cat out of the bag in case anyone needs one. Cool
429 cj intake gaskets without exhaust cross over Chokes10
Post  supervel45 October 23rd 2023, 6:52 pm
Paul Kane wrote:As an aside, should you opt to go with the non-OEM carb and wish to omit the OEM choke stove then we just finished a run of Choke Stove Block-Off Plates.  I haven't actually announced these yet but since we're on the subject I might as well let the cat out of the bag in case anyone needs one. Cool
429 cj intake gaskets without exhaust cross over 20231020
429 cj intake gaskets without exhaust cross over 20231021
429 cj intake gaskets without exhaust cross over 20231022
Excellent Part, Lighting Speed Shipping and Good Prices. Cool
Thanks Paul
Post  supervel45 October 23rd 2023, 7:01 pm
429 cj intake gaskets without exhaust cross over 20231023
All Needed Hardware Included Also. Smile
Post  rmcomprandy October 23rd 2023, 8:24 pm
70CobraDragpak wrote:So I have a 71 429cj with the Rochester carb on it and my choke doesn't work because there is no exhaust cross over to heat the choke stove spring. SOoo...I put an adapter plate and 870cfm Holley with electric choke on it yesterday. Are the gaskets w crossover available? I searched for awhile and gave up trying to find some. Alternatively I wonder how hard it would be to find an electric choke for the Rochester.... Also, my engine is basically stock w perhaps a slightly larger cam than stock. Is that 870 vac secondary going to be ok or will I need to modify something?
I have seen some GM cars having an electric choke on a Quadrajet carb with an entire non-divorced choke unit so, I know they are out there.
Some "cross-breeding" of the carb will be required to change the choke from a "divorced choke" to an "internal choke".
