Factory heads
Diggindeeper
OldRedFord
Factory heads Empty Factory heads
Post  OldRedFord December 31st 2009, 12:06 am
Did the 385 series and the 351M and 400M share identical blocks and heads?
First paragraph of page 5
http://www.carcraft.com/techfaq/116_9906_guide/index4.html
Im serious about this. I do not believe the article. Hell the guy says this about a 351 and I quote
These two ribs (arrows) at the back near the distributor clearly distinguish this as a 351 Windsor.
OldRedFord
OldRedFord
Factory heads Empty Re: Factory heads
Post  res0rli9 December 31st 2009, 12:19 am
Hes Wrong
Post  schmitty December 31st 2009, 1:06 am
351M, 351C and 400 were classified by Ford as the 335 series engine. Different bore spacing than 385. 335 and W series engines shared same bore spacing, and the heads from both can be interchanged with some mods depending on which switch is desired. Cool
Post  Diggindeeper December 31st 2009, 1:19 am
No i just think the way its written is confusing you. They are meaning the 429 and 460 share identical blocks, and the 351M and 400 share identical blocks. Not all of them sharing an Identical block.
the distributer thing, well........lets hope that was a serious brain fart, or editting problem.
Diggindeeper
Diggindeeper
Post  torkair December 31st 2009, 2:26 am
The article is poorly written, thats all. No way in a million years will cleveland heads bolt to a 429/460 block.
torkair
torkair
Post  chuck stevens December 31st 2009, 12:36 pm
Guy is a ucking fidiot. Very Happy
Last edited by chuck stevens on December 31st 2009, 10:36 pm; edited 1 time in total (Reason for editing : spellink)
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  bbf-falcon January 1st 2010, 11:21 am
They are not saying they are the same. read it again. They are saying the 429/460 share the same block and the same w/351m/400. Easily misread.
Post  rmcomprandy January 1st 2010, 11:57 am
I can't even count the number of times a writer has screwed with the real words they are quoting and mess it all up.
