Factory heads and intake
hpwdboss1
I pull in a tractor class that requires we use factory iron heads, block and intake manifold. We must use a 650 Holley and a MSD box with a 6k chip. A wide torque curve is best. Is there any benefit to cylinder head modifications (i.e. porting etc.)? Perry
hpwdboss1- Posts : 147
Re: Factory heads and intake
Cubic inch limit?
maverick- BBF CONTRIBUTOR
Stroke allowed?
FalconEh- Posts : 1448
Factory Iron
We run 500 c.i. or less, running 3.85 stroke and flat tappet. Pretty open other than that. We are at 14.8 to 1 comp ratio. Racing gas, no alcohol. Tuning mods only on carb. Perry
hpwdboss1 wrote:I pull in a tractor class that requires we use factory iron heads, block and intake manifold. We must use a 650 Holley and a MSD box with a 6k chip. A wide torque curve is best. Is there any benefit to cylinder head modifications (i.e. porting etc.)? Perry
My class is limited to 472,,, Iam running Iron heads,,, the last mods to them were strictly on the ex. side, if you want more in you have to get more out
samiam- Posts : 240
samiam wrote:hpwdboss1 wrote:I pull in a tractor class that requires we use factory iron heads, block and intake manifold. We must use a 650 Holley and a MSD box with a 6k chip. A wide torque curve is best. Is there any benefit to cylinder head modifications (i.e. porting etc.)? Perry
Port both you need to get all you can in with good air speed and use the cam to get it out.
Max effort port the factory iron heads, iron CJ intake, and offset stroke an OEM crankshaft to 4.125", 6.7" rod, 4.39" bore 1.54"-ish c/h piston, and you'll have a really good 499 CI platform to start with.hpwdboss1 wrote:I pull in a tractor class that requires we use factory iron heads, block and intake manifold. We must use a 650 Holley and a MSD box with a 6k chip. A wide torque curve is best. Is there any benefit to cylinder head modifications (i.e. porting etc.)? We run 500 c.i. or less... We are at 14.8 to 1 comp ratio. Racing gas, no alcohol. Tuning mods only on carb. Perry
Or you could stroke to 4.05", 6.7 rod, and a KB IC855 for a 490 (+0.030") to 497 (+0.060").....
Re; Factory heads and intake
Thanks for helping again, guys. Have spoken to Mr. C. Evans and going to work on a fresh pair of heads.
Perry
Perry
» Factory heads
» VAVLE HEIGHT SETUP RANGE FOPR OEM dove 429 HEADS
» 429 Factory Two barrel intake (cast) 1968
» Factory Aluminum Ford dual plane intake For Sale
» FACTORY IRON CJ HEADS DO0ER $1000.00
