Cam for cobrajet
Cam for cobrajet
I have a 71 torino cobra with 429cj 4speed manual and 3:50
Rear gears I want more performance but not ready for nor need complete rebuild at this time the car only has 43000 miles im wondering if anyone could tell me what cam I should install to get the most out of the otherwise factory set up
hk9176251- Posts : 8
Mark Miller, 1EFF100 and 2 wicked like this post
Re: Cam for cobrajet
Not sure on a cam but maybe Randy or Lem will chime in but you have a good looking ride
hk9176251 likes this post
Below is a 506HP Dynoed camshaft, when used with their heads and intake. It should make good HP with a CJ top end and compression.
Edelbrock Performer RPM. 234/244/108/.556/.581
https://www.ebay.com/itm/125129264203
Same Cam kit a little cheaper.
https://www.ebay.com/itm/285332190390?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D251363%26meid%3D6c8daa61850543ebab590b942d5eb43c%26pid%3D101195%26rk%3D1%26rkt%3D12%26sd%3D125129264203%26itm%3D285332190390%26pmt%3D1%26noa%3D0%26pg%3D4429486%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V4ItemNrtInQueryAndCassiniVisualRankerAndBertRecall%26brand%3DEdelbrock&_trksid=p4429486.c101195.m1851&amdata=cksum%3A2853321903906c8daa61850543ebab590b942d5eb43c%7Cenc%3AAQAIAAABUNaJCFP3eaFlNU%252FMPxRY0TCMczVKEUB5MsBytoCwPnd71M08lfrVO4PuTCchnU42KC4W4fZqxBROE%252BM7tSL%252BgZgL1kWiIUBRsEpydVTA61DhOJDUizwNgM7HKYQEqSaBlKy3pvcoiQfXXUAskmoXKVV66xred9Q%252B13iVwKaxcUGss1n%252BE%252FhEtqKMg34EIOK6jSDIyckkapRgIjN%252FU5qISB2Hm2nPP4I%252FBN6u9p0%252BXbgNfAwiurD6y2Z6igL3GpWSNJulfNMfvmanfsfnV3h6Anz3xMfJT9ONK1ctzp9KLnErK8X4YK20yqc2y7KAdcUXI%252BQ%252Fhv80srwmgGdHBF2vAURSp6ENZcs3uYXRHy%252Bncu39H2RkBPzXOU2e8xlupHQ%252Fml2yBlnPXt7INSkYDchp0%252FSXHjYM8SCjiBUiqUVTE6QnjVwqWnKaMIVhc99162s14A%253D%253D%7Campid%3APL_CLK%7Cclp%3A4429486&epid=179099137
The problem with most of the Big Block Ford heads is around .540"/.550" lift is you have to cut the valve guides so the valve seals don't get crushed.
There are very few BBF shelf cams in stock now.
In my opinion there never were many shelf grinds under or at .540" lift that were of a big improvement over the CJ and SCJ cams, without cutting the Guides. The tighter LSA offered by the cam companies in my opinion was their strong point, especially when many owners were taking compression out of them to run on lower octane pump gas.
As said Randy can grind you a custom cam to get around the lift issue and taylor it to you setup.
Is the engine in the car and running now?
Still Original Q-Jet and Intake?
Headers?
Headers?
supervel45- Posts : 4499
The 429CJ hydraulic cam C9AZ-6250-C is a pretty good piece.
I personally like the CompCams "Specialty" camshaft 34-244-4 / 268AH-10 for your type requirements.
268/276 @.006" - 222/226@.050" - ,535"/.535" valve lift - 110 separation but, in this day and age, (with the unavailable core issue), you will get whatever is close that you can get.
The Howard's Cam number 240041-12 is only slightly bigger than that and is a really good cam for your type situation, also.
EDIT: I have used both of these cams with good success.
I will never recommend anything which I have not actually used although, there may be other stuff out there like it.
69F100 wrote:Not sure on a cam but maybe Randy or Lem will chime in but you have a good looking ride
X2!!
Mark Miller- Posts : 1959
You can get a lot out of the lower lift Stock and Super Stock type cams. The below is a 1970 Torino 429 SCJ at 12.56 in the 1/4. That is why I suggested a custom grind.
https://www.youtube.com/watch?v=s0i3PUtcHm8
Back in the day Erson had some good .545" dual pattern cams. E260520 and E26721. Same cams one had 5 degree's advance cut in. Electric page 140 Actual page 138.
http://www.pbm-erson.com/UserFiles/Documents/Catalogs/Erson-Master-Catalog-2020-web.pdf
Thank you and about intake and carb Theo only thing not factory on the car at this time is protonics electronic ignition replacement for duel points
quote="supervel45"]Below is a 506HP Dynoed camshaft, when used with their heads and intake. It should make good HP with a CJ top end and compression.
Headers?[/quote]
Headers?[/quote]
» FE 428 Cobrajet .030 over FOR SALE
» New Ford Racing Performer RPM intake ported and NIB Victor intake for Dominator
» WANTED A429 COBRAJET ALUM HEADS
» Craigslist find New 429-460 aluminum super cobrajet heads
