Boss 9 lifters
Boss 9 lifters
Are z bar style lifters required for kasse boss 9 heads? Reason i ask I've got a new set if crowers I'm hoping to use. Block is still at machine shop so I'm not able to mock it up
fordmonsta- Posts : 236
Re: Boss 9 lifters
Yes z bar style required
BOSS 429 and fordmonsta like this post
Re: Boss 9 lifters
fordmonsta wrote:Are z bar style lifters required for kasse boss 9 heads? Reason i ask I've got a new set if crowers I'm hoping to use. Block is still at machine shop so I'm not able to mock it up
I have used hydraulic roller lifters with Boss9 heads and the straight tie-bars worked but, the pushrodss were a lot shorter and seated at the top of the lifters.
With the pushrods seating inside the lifter and 5/8" longer pushrods it is a different story.
ISKY used to sell "high button" solid roller lifters, I don't know if they still do.
boss lifters
any chance the straight tie bar lifters would work with an offset seat and a long taper on the pushrod?
hbstang- Posts : 365
Re: Boss 9 lifters
The reason for the need of the z bar is because of the laid down ehx push rod. I have not seen any straight links that will not cause a problem/interference of push rod thru the lift of the cam
-R
-R
BOSS 429- Posts : 2372
boss lifters
rich,i think the intake pushrod requires the z bar lifters to clear.exhaust just has a lot of angle,but with liters to the inside of the block the intake pushrods interfere with top of the straight link
Re: Boss 9 lifters
Pushrod contact with the rivets holding the tie bar is usually the issue with a straight tie bar; given the pushrod angle.
Re: Boss 9 lifters
hbstang wrote:rich,i think the intake pushrod requires the z bar lifters to clear.exhaust just has a lot of angle,but with liters to the inside of the block the intake pushrods interfere with top of the straight link
Ill post some pics sometime to show ya its the ehx side thats the prob ,more so with a good push rod
» Jesel lifters vs Bushing Lifters
» Boss 9 z-bar solid roller lifters
» Kaase boss 429 heads, rockers, and lifters
» BOSS 429 SOLID ROLLER LIFTERS, NEW,CORES COMP CAMS
» SOLD - Used Jesel .937 Keyway Lifters - 2 sets (1 full, 1 w/15 lifters)
