"antiseize" on dist housing?
"antiseize" on dist housing? Empty "antiseize" on dist housing?
Post  Kobelco September 2nd 2023, 4:53 pm
I rebuilt a 90's motorhome  460 over ten years ago it has seen 15k miles, completely stock I installed a rebuilt cardone TFI distributor I lubed the housing w really heavy wheel bearing grease no bind up in install. This was for a family member they needed to remove the dist to replace PIP it required a strap wrench to get it to turn it did not break but they ordered a new Cardone not to take a chance on other one being twisted-bent. All the grease was gone melted away,  what do you guys\gals use to keep a dist from seizing in block?
Kobelco
"antiseize" on dist housing? Empty Re: "antiseize" on dist housing?
Post  rmcomprandy September 2nd 2023, 6:10 pm
Kobelco wrote:I rebuilt a 90's motorhome  460 over ten years ago it has seen 15k miles, completely stock I installed a rebuilt cardone TFI distributor I lubed the housing w really heavy wheel bearing grease no bind up in install. This was for a family member they needed to remove the dist to replace PIP it required a strap wrench to get it to turn it did not break but they ordered a new Cardone not to take a chance on other one being twisted-bent. All the grease was gone melted away,  what do you guys\gals use to keep a dist from seizing in block?
Moly paste or anti-seize.
