Block filler
Block filler
Hey Everyone,
I keep seeing everyone talking about filling their blocks to the water pump holes, and I understand the reasoning behind this, BUT my thinking is that it is more important to fill EVENLY around the cylinders. Example: turning one side of engine deck vertically and filling evenly from the water jacket holes, letting it set up, then repeat for opposite bank(I hope i'm describing this well enough). This would ensure that the lower(or outer ) side of each cylinder doesn't have a difference in temperature to its upper(or inner ) side. Am I making sense to anyone? Just asking....Filled my block this way, to about 2 inches below the deck.
mitch huested- Posts : 19
Gregaust likes this post
Re: Block filler
That’s what filling to the water pump holes does….. you fill up the block with the deck leve untill the level reaches the water pump holes.
Re: Block filler
Yes that's typically how it's done--rotate the block on the stand until one of the decks is straight up. Clean thoroughly the area that will get filled and be sure to use a level on the deck surface (both parallel to the bank and perpendicular) to assure the fill will surround the cylinders as you describe.mitch huested wrote:Hey Everyone,
I keep seeing everyone talking about filling their blocks to the water pump holes...BUT my thinking is that it is more important to fill EVENLY around the cylinders. Example: turning one side of engine deck vertically and filling evenly from the water jacket holes, letting it set up, then repeat for opposite bank(I hope i'm describing this well enough)...Am I making sense to anyone? Just asking....Filled my block this way, to about 2 inches below the deck.
As of late I've been using RokBlock engine block filler (Competition Products). It's very easy to use, just follow the instructions exactly. I usually start with refrigerated water, and as the filler begins to set up in the block I've recorded it getting as high as 115* F on my infrared gun. It helps immensely to have someone assisting you with the prep and pour, especially the first time.
Gregaust and Mark Miller like this post
Re: Block filler
YES ... having some kind of mild vibration when the fill is setting-up will purge all the air out of the filler.
I just put a "woofer" speaker from a radio on top the deck.
For many years I have used 885 metallic, aggregate grout, (used to be Embico but, now from BASF), for fill. It works great but, a 40 lb.bag will fill about 4 to 5 blocks so, probably not a good deal for someone just wanting 1 block filled.
Re: Block filler
rmcomprandy wrote:mitch huested wrote:Hey Everyone,
Got to watch using the Embeco antifreeze will attack it, needs sealed
Re: Block filler
dfree383 wrote:rmcomprandy wrote:mitch huested wrote:Hey Everyone,
Not any of the blocks I have filled over the past 50 some years ... the mix needs to be correct.
» HARD BLOCK FILLER
» block filler and boring recomendation
» C6 filled tube plug
» Bolt on oil filler cap and breather?
» Custom Filler Neck
